Apple Homekit(Siri) integration with Homeseer
    #91
    But then I start adding accessories...
    Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 0012f4f2-cd73-4bf6-8ed0-6ba182637d59
      #92
      Hey stipus, thanks for doing this. Is there any way to use it with a homeseer user and password? Mine is user/pass protected...
        #93
        Sigh... I just have to rename all the devices in my house.
          #94
          No you can add a name property for each device in the config file
          stipus
            #95
            You are the first to ask.... I'll do this
            stipus
              #96
              Hmm... I'll have to take a look at that. Is there a list of all properties we can define someplace?
                #97
                At the beginning of the file platforms/HomeSeer.js
                You can always override the HomeSeer name using the name property, such as in the following example:
                "ref":9,
                "type":"Lightbulb",
                "name":"Lampe Orange",
                "onValue":101
                stipus
                  #98
                  Never mind... RTFM. Sorry, I'm looking at your HomeSeer.js Example.
                  Thank you Stipus
                    #99
                      In fact it already works with HomeSeer authentication.
                      In the platform configuration you can add the homeseer user and password in the host parameter.
                      PHP Code:
                      "host":"http://user:password@ip_address"
                      I just tested with user stipus and password test
                      PHP Code:
                      "platform""HomeSeer",
                      "name""HomeSeer",
                      "host""http://stipus:test@192.168.3.4:81",
                      "accessories":[ .......
                      stipus
                        Here is (attached) a new version of the HomeSeer Platform with Thermostat support.
                        Example configuration:
                        PHP Code:
                         "platforms": [
                        "platform""HomeSeer",              // Required
                        "name""HomeSeer",                  // Required
                        "host""http://192.168.3.4:81",     // Required - If you did setup HomeSeer authentication, use "http://user:password@ip_address:port"
                        "accessories":[
                        "ref":8,                        // Required - HomeSeer Device Reference (To get it, select the HS Device - then Advanced Tab)
                        "type":"Lightbulb",             // Optional - Lightbulb is the default
                        "name":"My Light",              // Optional - HomeSeer device name is the default
                        "offValue":"0",                 // Optional - 0 is the default
                        "onValue":"100",                // Optional - 100 is the default
                        "can_dim":true                  // Optional - true is the default - false for a non dimmable lightbulb
                        "ref":9                         // This is a dimmable Lightbulb by default
                        "ref":58,                       // This is an controllable outlet
                        "type":"Outlet"
                        "ref":111,
                        "type":"TemperatureSensor",     // Required for a temperature sensor
                        "temperatureUnit":"F",          // Optional - C is the default
                        "name":"Bedroom temp"           // Optional - HomeSeer device name is the default
                        "ref":113,                      // Required - HomeSeer Device Reference of the Current Temperature Device
                        "type":"Thermostat",            // Required for a Thermostat
                        "name":"Température Salon",     // Optional - HomeSeer device name is the default
                        "temperatureUnit":"C",          // Optional - F for Fahrenheit, C for Celsius, C is the default
                        "setPointRef":167,              // Required - HomeSeer device reference for your thermostat Set Point.
                        "setPointReadOnly":true,        // Optional - Set to false if your SetPoint is read/write. true is the default
                        "stateRef":166,                 // Required - HomeSeer device reference for your thermostat current state
                        "stateOffValues":[0,4,5],       // Required - List of the HomeSeer device values for a HomeKit state=OFF
                        "stateHeatValues":[1],          // Required - List of the HomeSeer device values for a HomeKit state=HEAT
                        "stateCoolValues":[2],          // Required - List of the HomeSeer device values for a HomeKit state=COOL
                        "stateAutoValues":[3],          // Required - List of the HomeSeer device values for a HomeKit state=AUTO
                        "controlRef":168,               // Required - HomeSeer device reference for your thermostat mode control (It can be the same as stateRef for some thermostats)
                        "controlOffValue":0,            // Required - Value for OFF
                        "controlHeatValue":1,           // Required - Value for HEAT
                        "controlCoolValue":2,           // Required - Value for COOL
                        "controlAutoValue":3,           // Required - Value for AUTO
                        "coolingThresholdRef":169,      // Optional - Not-implemented-yet - HomeSeer device reference for your thermostat cooling threshold
                        "heatingThresholdRef":170       // Optional - Not-implemented-yet - HomeSeer device reference for your thermostat heating threshold
                        Attached file removed, as it is now included in the latest homebridge distribution
                        stipus
                          PHP Code:
                          PHP Code:
                          "name""HomeSeer",
                          Cool. Should have tried that. Thanks.
                            Anybody know how I might add the nest platform when you have 2 thermostats?
                            When I add:
                            "platform" : "Nest",
                            "name" : "Nest",
                            "username" : "username",
                            "password" : "password"
                            I get this error:
                            [Nest] Initializing platform accessory 'Nest'...
                            /root/homebridge/node_modules/HAP-NodeJS/lib/Accessory.js:164
                            throw new Error("Cannot add a bridged Accessory with the same UUID as an
                                I think that this brings us to the same subject back 11 years ago when I created MLHSPlugin. Essentially it was a bridge between HomeSeer and MLServer just like HomeBridge is a bridge between Homekit and HS.
                                Rather than worry about mapping every single device, it is subjectively more efficient to create scenes that perform the desired functionality and then execute them. This will decrease the number of devices needed to be entered and essentially will make home automation more usable.
                                I have over a thousand different devices in HomeSeer. There is no way that I would ever remember every single name of each device. Therefore, I will logically map out my home into various scenes depending the various "modes" that my house would normally be in and create mappings between HomeKit scenes to HomeSeer scenes.
                                Re-reading your earlier post I now have a better understanding how scenes can be "bridged" between HomeKit and HomeSeer. Bringing back visibility to this as I think this is the key to success.
                                I think it's possible to publish HS Events as HomeKit stateless switches through HomeBridge. Unfortunately I don't think a HomeKit Accessory Server can publish a HomeKit scene.
                                HomeSeer has a JSON API to run an event, and it should be easy to add a "events" section to the config.json file, and create a HomeKit switch for each event.
                                Then you can easily create a HomeKit scene with the name you want, that runs the HomeSeer event.
                                HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
