Rebooting HS3 Server Causing Problems.
    Whenever I reboot the Windows 8.1 64bit HomeSeer server, I'm getting Z-NET connection problems. Sometimes I am not even able to open the plug-in manager.
    HS3 Pro Edition 3.0.0.177 (Windows) ---- Z-NET 3.0.1.7
    The only way to correct it is to power cycle the Z-NET
    Here are portions of the log
    May-26 9:21:34 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:21:34 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:21:33 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:21:33 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:21:32 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:21:26 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:21:26 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:21:26 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:21:26 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:21:25 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:21:23 PM           MySensors     | PLUGIN | STATUS | : MySensors.S_TEMP (7, 0) - Status changed to 69.2°C
    May-26 9:21:23 PM           MySensors     | PLUGIN | DEBUG | : MySensors.S_TEMP (7, 0) - MySensors message received.
    May-26 9:21:23 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 7;0;1;0;0;69.2
    May-26 9:21:23 PM           MySensors     | MYSENSORS | INFO | : read: 7-7-0 s=0,c=1,t=0,pt=7,l=5:69.2
    May-26 9:21:23 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 0;0;3;0;9;read: 7-7-0 s=0,c=1,t=0,pt=7,l=5:69.2
    May-26 9:21:18 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:21:18 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:21:18 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:21:18 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:21:17 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:21:05 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:21:05 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:21:05 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:21:05 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:21:04 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:44 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:20:44 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:20:43 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:20:43 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:20:42 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:35 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:20:35 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:20:35 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:20:35 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:20:34 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:25 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:20:25 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:20:25 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:20:25 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:20:24 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:23 PM           TTS     Speak ():Welcome to Home-Seer
    May-26 9:20:22 PM           MySensors     | PLUGIN | STATUS | : MySensors.S_ARDUINO_NODE (2, 255) - Battery level is 31
    May-26 9:20:22 PM           MySensors     | PLUGIN | DEBUG | : MySensors.S_ARDUINO_NODE (2, 255) - MySensors message received.
    May-26 9:20:22 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 2;255;3;0;0;31
    May-26 9:20:22 PM           MySensors     | MYSENSORS | INFO | : read: 2-2-0 s=255,c=3,t=0,pt=1,l=1:31
    May-26 9:20:22 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 0;0;3;0;9;read: 2-2-0 s=255,c=3,t=0,pt=1,l=1:31
    May-26 9:20:22 PM           MySensors     | PLUGIN | STATUS | : MySensors.S_HUM (2, 0) - Humidity level is 44%.
    May-26 9:20:22 PM           MySensors     | PLUGIN | DEBUG | : MySensors.S_HUM (2, 0) - MySensors message received.
    May-26 9:20:22 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 2;0;1;0;1;44.0
    May-26 9:20:22 PM           MySensors     | MYSENSORS | INFO | : read: 2-2-0 s=0,c=1,t=1,pt=7,l=5:44.0
    May-26 9:20:22 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 0;0;3;0;9;read: 2-2-0 s=0,c=1,t=1,pt=7,l=5:44.0
    May-26 9:20:14 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:20:14 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:20:14 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:20:14 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:20:13 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:06 PM           weatherXML     Run between 0 23
    May-26 9:20:06 PM           weatherXML     Run timer items
    May-26 9:20:05 PM           Z-Wave     *******************************************************************************
    May-26 9:20:05 PM           Z-Wave     STARTUP COMPLETE: All configured interfaces were successfully initialized.
    May-26 9:20:04 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:20:04 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:20:04 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:20:03 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 9:20:02 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 9:20:00 PM           Web Server     Web Server authorized local login successful from: 192.168.1.75 User: ServiceXp
    May-26 9:19:53 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 9:19:53 PM           Z-Wave     Z-NET_One: Processing data buffered by the interface while it was disconnected.
    May-26 9:19:52 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 9:19:52 PM           Z-Wave Error     Z-NET_One: Exception transmitting to IP 192.168.1.76: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
    May-26 9:04:52 PM           Error     Getting web page from plugin page ZWaveControllers:Object reference not set to an instance of an object.
    May-26 9:04:24 PM           MySensors     | PLUGIN | STATUS | : MySensors.S_TEMP (7, 0) - Status changed to 69.3°C
    May-26 9:04:24 PM           MySensors     | PLUGIN | DEBUG | : MySensors.S_TEMP (7, 0) - MySensors message received.
    May-26 9:04:24 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 7;0;1;0;0;69.3
    May-26 9:04:24 PM           MySensors     | MYSENSORS | INFO | : read: 7-7-0 s=0,c=1,t=0,pt=7,l=5:69.3
    May-26 9:04:24 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 0;0;3;0;9;read: 7-7-0 s=0,c=1,t=0,pt=7,l=5:69.3
    May-26 9:04:06 PM           MySensors     | HOMESEER | STATUS | : HSEvent: CONFIG_CHANGE
    May-26 9:04:06 PM           Error     Calling HSEvent in plugin Z-Wave, Instance :Object reference not set to an instance of an object.
    May-26 9:04:06 PM           Error     Calling SetIOMulti in plugin Z-Wave:Object reference not set to an instance of an object.
    May-26 9:04:02 PM           Warning     Plugin Z-Wave is not responding but it is still running, not restarting yet.
    May-26 9:00:32 PM           Warning     Plugin Z-Wave is not responding but it is still running, not restarting yet.
    May-26 9:00:28 PM           Error     Calling HSEvent in plugin Z-Wave, Instance :Object reference not set to an instance of an object.
    May-26 9:00:26 PM           Error     Calling ConfigDevice in plugin Z-Wave:Object reference not set to an instance of an object.
    May-26 8:52:43 PM           Z-Wave     Z-NET_One: Controller firmware version: 4.32
    May-26 8:52:43 PM           Z-Wave     Z-NET_One: Controller Manufacturer: HomeSeer Tech, ID=0x2, Type=0x5
    May-26 8:52:43 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:43 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:43 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:43 PM           Z-Wave Warning     In Z-Wave init(A), no response getting initialization information.
    May-26 8:52:39 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:39 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:39 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:38 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:38 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:38 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:38 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:37 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:34 PM           Device Control     Device: Attic Z-Wave_Appliance_Sw Attic_Fan_Switch to On (255)
    May-26 8:52:34 PM           Event     Event Trigger "Temperature_Control Attic_Fan_On"
    May-26 8:52:34 PM           MySensors     | PLUGIN | STATUS | : MySensors.S_TEMP (2, 1) - Status changed to 87.1°C
    May-26 8:52:34 PM           MySensors     | PLUGIN | DEBUG | : MySensors.S_TEMP (2, 1) - MySensors message received.
    May-26 8:52:34 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 2;1;1;0;0;87.1
    May-26 8:52:34 PM           MySensors     | MYSENSORS | INFO | : read: 2-2-0 s=1,c=1,t=0,pt=7,l=5:87.1
    May-26 8:52:34 PM           MySensors     | MYSENSORS | DEBUG | : MySensors.Gateway - Message received: 0;0;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5:87.1
    May-26 8:52:27 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:26 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:26 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:25 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:20 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:20 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:20 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:19 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:18 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:18 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:18 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:17 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:17 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:16 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:16 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:15 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:05 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:52:05 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:52:05 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:52:04 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:52:00 PM           weatherXML     Run between 0 23
    May-26 8:52:00 PM           weatherXML     Run timer items
    May-26 8:51:59 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:59 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:59 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:58 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:57 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:56 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:56 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:55 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:55 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:55 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:55 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:54 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:44 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:44 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:44 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:43 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:38 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:38 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:38 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:37 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:35 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:35 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:35 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:34 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:34 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:34 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:34 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:33 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:23 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:23 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:23 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:22 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:17 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:16 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:16 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:15 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:14 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:14 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:14 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:13 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:13 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:13 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:13 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:12 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    May-26 8:51:02 PM           Z-Wave     Z-NET_One: Getting node information from controller...
    May-26 8:51:01 PM           Z-Wave     Z-NET_One: Z-Wave Ethernet at IP 192.168.1.76, connected to interface ok.
    May-26 8:51:01 PM           Z-Wave Warning     Trying to re-connect to Ethernet interface at IP 192.168.1.76...
    May-26 8:51:00 PM           Z-Wave Error     Z-NET_One: The Z-NET_One interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning.
    RJ_Make On YouTube
    Should I uninstall HS3 (and plug-ins) and start over again?
    RJ_Make On YouTube
      I had the same problem when I rebooted last, and power cycling the Znet was the solution as well. I don't remember having this issue prior to the last Zwave PI version, so I'd bugzilla it, sounds like the Znet device isn't handling reconnects very well.
      Z
        Bug #?
        RJ_Make On YouTube
          Originally posted by ServiceXp View Post
          Bug #?
          Sorry, I was being lazy and was suggesting you do it
          Z
            Ah... I missed that... Will do.. But I think you should too..
            RJ_Make On YouTube
              Bug 2784
              RJ_Make On YouTube
