My main HSTouch screen is in the living room, an Asus EEE box connected wirelessly to my Pro100 located in the garage. It works just great, however the IP address of the Pro100 constantly changes. It is very frustrating as I have to pull out the keyboard and mouse and change the IP address in HSTouch client. The Pro100 is hardwired into my WRT54GS router. Is there a way to make the IP address for the Pro100 static? Do I have to get Comcast give me a static IP? It is the local network IP that constantly changes. Thanks for any help!
Changing IP address
termiteTags: None
Originally posted by termite View PostIs there a way to make the IP address for the Pro100 static? Do I have to get Comcast give me a static IP? It is the local network IP that constantly changes. Thanks for any help!-Skybolt
termite
Thanks Skybolt, That would save some time changing the IP address back, but it would sure be nice if it did'nt change in the first place.
Originally posted by termite View Postbut it would sure be nice if it did'nt change in the first place.
It doesn't have a choice, if DHCP was not enabled how would it ever get an IP Address. In some routers you can "Reserve" an IP address which is DHCP, spme of teh higher end Linksys and NetGear routers have this - there newer business class ones.-Skybolt
Why not give the Pro100 a static IP on your lan?
Just see what ip address / subnet / gateway / dns it has now and then enter them in as static numbers. I believe on the pro100 you would need to commit the changes to the system drive?
Then change your dhcp settings on your router to exclude that address.Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
why not just make ALL the addresses on your internal lan static, How many devices do you have that use an IP addressOver The Hill
What Hill?
Where?
When?
I Don't Remember Any Hill
Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
termite
