Go Back   HomeSeer Message Board > Weather Plug-ins > Weather Discussion
Old December 1st, 2017, 02:54 PM
Otto-mation Otto-mation is offline
Seer Plus
Anyone having problems with Environment Canada plugin?
Hi folks, is it just me, or is anyone else having problems with the Environment Canada plugin? Mind was working fine for for two cities and just stopped working the morning of Nov 21, 2017 with the log showing error:
error in feed: https://weather.gc.ca/rss/city/on-54_e.xml - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Attempts to contact both the developer and Environment Canada have been unsuccessful so far so I am wholly open to suggestions.
I also tried using both HTTP and HTTPS links as well as a different city, with no luck.
Cheers!
-steve
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 1 Day 15 Hours 31 Minutes 5 Seconds
Number of Devices: 329
Number of Events: 180
Available Threads: 399
Enabled Plug-Ins
3.0.0.5: CM15A
3.0.0.42: EasyTrigger
3.0.0.17: EnvCan
3.0.1.130: Z-Wave
Old December 11th, 2017, 02:45 AM
chrisgo chrisgo is offline
Seer Deluxe
Cheers!
I just tried your feed over port 80 and it worked fine. Please see the other thread for additional suggestions.
HTML code is Off
Environment Canada Weather plugin - HS3 chrisgo Weather Discussion 105 July 2nd, 2018 10:21 AM
Environment Canada Weather/Weather Warnings Wadenut Script & Plug-In Library Discussion 300 November 8th, 2017 11:22 AM
HS dev environment petez69 HS3 / HS3PRO Discussion 0 March 2nd, 2016 12:35 AM
[VB.NET] CANADIANS: Environment Canada Weather/Weather Warnings Wadenut Script & Plug-In Library 0 November 19th, 2011 02:13 PM
Using VR in noisy environment sportera HomeSeer General Discussion Area 4 February 17th, 2005 01:37 PM
