Spud,
I've installed your trial plugin yesterday and have these questions :
1 - The plugin is relying on polling while Neviweb seem to be updating almost instantly with push data. Is this an API limitation or was there other programming reasons being considered. I tried putting the "Poll" to zero but no luck. I'm moving from Stelpro Ki to Sinope because they have in floor heating TStat with 2nd stage output and long cycle capability. What I really liked about the Ki was the immediate values broadcast and update.
2 - This one might be related to HS UI or my current understanding of it. I wanted to fine tune the "Status graphic" properties and the more I try to either change them or even bring them back to their initial values, the more they look weird. In short, are you managing these properties beyond their initial creation? I will probably end-up deleting the root device and re-discover it.
Thanks.
Thanks.
