Referencing a virtual thermostat/set point switch
    Brian,
    I don't think you can compare the values of two devices with standard HS3 events but you can do it if you have the EasyTrigger plug-in. EasyTrigger adds lots of useful triggers, conditions, grouping etc.
    Alternatively it is relatively easy to compare device values with a script if you can program.
    A further alternative, for what you are doing, would be to give my free Virtual Thermostats plug-in a try (SDJ-VStat).
    https://forums.homeseer.com/forumdisplay.php?f=1569
    Steve
      Originally posted by SteveMSJ View Post
      Brian,
      Steve
      Hi Steve
      What a great plugin, it does exactly what I require, although ive still to work out some of the functions. Cheers
        Originally posted by Brizeeafc View Post
        Hi Steve
        If you need any help with the plugin just start a thread in the sub forum. The guide might not be as clear as it could be..
        Steve
