is there something procedure wise for Windows, I'm assuming your coping your HS3 directory and associated files. Can someone then take them and run them on another machine?
Yes. Using the Linux explorer you can also right click and hit compress to whatever format you like.
For Windows you could do install 7-Zip and use explorer in admin mode, right click on the directory and zip it.
Obviously the z-wave devices are not there so that not everything will run.
The Z-Wave devices are stored in a database. You would just have to restore the devices to whatever Z-Wave device you have plugged in.
