Trying plugin, added HS Devices (digital outputs) to plugin. Valves wont turn on (because plugin uses HSExec10?) Any way around this? Thanks!
Can Plugin Control Ocelot SECU Relays?
To my knowledge the ocelot plugin should respond to ON and OFF commands to control the SECU points. It does work that way with ADIOcelot. If it is only responding to SetDeviceValue 1 and 0 then I will accomodate. You can do the test at your end with the script commands below to turn on a point. Change ^1 to whatever the point's device code may be. If they both work then the difficulty you are seeing is elsewhere, but the intent is to be able to control an two-state homeseer device.
hs.ExecX10 "^1", "ON"
hs.SetDeviceValue "^1", 1
