This is a new nearly un-programmed Omni2 Pro. We've only defined zones. When we try to run the plugin, we get this in the logs:
2/2/2010 2:53:33 PM
Updater
Starting installation of updates
2/2/2010 2:53:33 PM
Updater
Applying update: HAI Panel Plug-in
2/2/2010 2:53:33 PM
Updater
Copying file: C:\Program Files\HomeSeer HS2\scripts\HAI_System_Check.txt
2/2/2010 2:53:33 PM
Updater
Extracting files from zip file: WebHelp.zip
2/2/2010 2:53:40 PM
Updater
Extraction Complete.
2/2/2010 2:53:40 PM
System
Un-registering C:\Program Files\HomeSeer HS2\hspi_HAI.exe with Windows
2/2/2010 2:53:43 PM
Updater
Copying file: C:\Program Files\HomeSeer HS2\hspi_HAI.exe
2/2/2010 2:53:43 PM
System
Registering C:\Program Files\HomeSeer HS2\hspi_HAI.exe with Windows
2/2/2010 2:53:45 PM
Updater Warning
File exists, not overwriting: C:\Program Files\HomeSeer HS2\Config\HAI_System.lf
2/2/2010 2:53:45 PM
Updater
Installation of updates completed
2/2/2010 2:53:45 PM
Startup
Restoring Device Status
2/2/2010 2:53:45 PM
Z-Wave
:- :- :- :- :- :- :- :- Initializing Z-Wave Interface -: -: -: -: -: -: -: -:
2/2/2010 2:53:45 PM
Z-Wave
Initializing Z-Wave Interface on COM port: 4 at 115K baud.
2/2/2010 2:53:49 PM
Warning
In Z-Wave init, no response getting initialization information.
2/2/2010 2:53:49 PM
Z-Wave
Z-Wave interface version: 0
2/2/2010 2:53:49 PM
Z-Wave
Z-Wave interface node ID: 0, Home ID:
2/2/2010 2:53:49 PM
Z-Wave
Found 0 Z-Wave nodes
2/2/2010 2:53:49 PM
Z-Wave Error
(Init/Sync) Initializing Z-Wave Interface: Could not communicate with the interface to get the version.
2/2/2010 2:53:49 PM
Z-Wave
2/2/2010 2:53:49 PM
System
Registering hs_compatibility.exe with Windows
2/2/2010 2:53:51 PM
Error
Unable to initialize HomeSeer 1.x compatibility interface: Retrieving the COM class factory for component with CLSID {4B3C1F4A-4B61-4897-B13F-5DF3D40C7954} failed due to the following error: 80040154.
2/2/2010 2:53:51 PM
Startup
Checking for available plug-ins
2/2/2010 2:53:51 PM
Plug-In
Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
2/2/2010 2:53:51 PM
Plug-In
Found plug-in: X10 CM15AUSB, version: 1.0.0.3
2/2/2010 2:53:51 PM
Error
Cannot access plug-in (may need to be re-installed): HSPI_HAI.HSPI -> Object variable or With block variable not set.
We're not sure how to proceed. Exact firmware version is still unclear, but should be 3.x as we bought this Omni last Summer.
-KP
2/2/2010 2:53:33 PM
Updater
2/2/2010 2:53:33 PM
Updater
2/2/2010 2:53:33 PM
Updater
2/2/2010 2:53:33 PM
Updater
2/2/2010 2:53:40 PM
Updater
2/2/2010 2:53:40 PM
System
2/2/2010 2:53:43 PM
Updater
2/2/2010 2:53:43 PM
System
2/2/2010 2:53:45 PM
Updater Warning
2/2/2010 2:53:45 PM
Updater
2/2/2010 2:53:45 PM
Startup
2/2/2010 2:53:45 PM
Z-Wave
2/2/2010 2:53:45 PM
Z-Wave
2/2/2010 2:53:49 PM
Warning
2/2/2010 2:53:49 PM
Z-Wave
2/2/2010 2:53:49 PM
Z-Wave
2/2/2010 2:53:49 PM
Z-Wave
2/2/2010 2:53:49 PM
Z-Wave Error
2/2/2010 2:53:49 PM
Z-Wave
2/2/2010 2:53:49 PM
System
2/2/2010 2:53:51 PM
Error
2/2/2010 2:53:51 PM
Startup
2/2/2010 2:53:51 PM
Plug-In
2/2/2010 2:53:51 PM
Plug-In
2/2/2010 2:53:51 PM
Error
-KP
