My Insteon 2413U seems to have died last night. No light and it doesn't control anything from HS3. The system sees it go and come back on COM6 if I unplug it, but Mark's Insteon Plugin says it can't see it.
It is not responsive to any HS3 commands sent from HS3 or incoming.
I bought another and it's on the way, but how do I replace it with regard to the HS3 Plug-in? Do I just plug it in in place of the old one and carry on, or do I have to re-scan all the Insteon devices and reprogram it? Will my Device IDs be the same?
On a related note, I have one Insteon switch that when turned on/off flashes RED on the LEDs. No others do this. So, I bought a replacement dimmer switch, too, because I'm wondering if this switch may be jabbering in Insteon-speak and that is causing problems. No power glitches have occurred as far as I know.
Any tips from someone who's changed one of these out? From Mark? Thanks in advance!
