I upgraded from Zee S2 to SEL. Both run HS3.
I was curious can I connect both to the same Z-NET zwave controller?
The reason I ask is I can't get the Harmony Plug In to work with the SEL. At this point I have little hope i will get it working. But the plugin works fine on the Zee S2.
So if I could connect the Zee S2 to the zwave network the SEL is using, i could in in theory use the devices from the plugin and the zwave decives to make events on my Zee S2.
It would not be the end of the world to keep the Zee S2 around just to handle the Harmony stuff.
If not I will just peel off some of the zwave devices i use to control the AV and include them in the Zee S2 network.
My main use for the plugin is to control Harmony AV devices from physical switches. Not your typical use case, but I love double tapping a switch downstairs and it muting the kids tv, or holding down a fibario button and it shutting down the kids AV stuff completely. Just much easier than taking my harmony app out or waiting for the kids to respond to my "shut off the F**ing tv" command. LOL.
