Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Sooty Plug-Ins > PHLocation Plug-in (3P)
Old February 15th, 2017, 10:12 PM
pcp pcp is offline
Super Seer
Error with version 3.0.1.83 and Locative
With the latest update when Locative calls the plugin phlgeofancy, it fails with the following error in the log. I did not run into this with the prior version I was using. LOcative's error is something like "No readable response received".
Quote:
(WriteTohttpLog) Error! System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\PHLocation\Logs\httplog_20170215.txt' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at p.g(String A_0)
Old February 16th, 2017, 02:16 AM
sooty sooty is offline
Super Seer
Quote:
The log message appears to suggest that you have log http requests to file switched on but the log file is not able to be accessed.
Writing to the log file is a separate process to returning a response to Locative.
Can you:
1. Set debug level to 2
2. Send a test from Locative
3. Email me the resulting HS3 log entries from the test
Paul..
Old February 16th, 2017, 09:36 PM
pcp pcp is offline
Super Seer
Can you:
Paul..
Yes I had the "log http requests to file switched on"; I turned it off and that message went away. Otherwsie I sent you the log output from the request test.
Old February 16th, 2017, 09:41 PM
pcp pcp is offline
Super Seer
FYI: I tried BTraced and worked fine.
Old February 17th, 2017, 01:52 AM
Super Seer
The Locative error should be fixed in 3.0.1.84.
https://forums.homeseer.com/showpost...06&postcount=1
Paul..
Old February 17th, 2017, 12:26 PM
pcp pcp is offline
Super Seer
3.0.1.84 resolved it. Thank you for the quick turnaround.
HTML code is Off
Error with version 2.15.0.22 vasrc mcsSprinklers 1 July 15th, 2015 10:11 PM
Error message in new version skozin Windows Media Player 18 December 4th, 2006 02:03 PM
Keep getting version mismatch error. Help! Wazoo Windows Media Player 4 October 7th, 2006 11:01 AM
Getting Error with version 1.19.0.22 and HS2 Per4merKC SpeakEasy Plug-In 3 September 29th, 2005 11:37 AM
Run-time error '5' on version 3.1.3 JimBob Hauppauge Capture (3P) 5 March 23rd, 2004 05:46 PM
