Just tried the 304 build... but it seems the wrong version has been put online. After startup, nothing worked, all plugins failed etc...
Then I noticed this:
This HS3ZEE version of HomeSeer is not registered and is running as a trial, 7 days remaining.
I had to restore from backup to get HS3 running again... I couldn't simply "update" to the 300 build again as several settings were changed, and the HS3Pro license was removed...
