I case my Z-Net runs into problems, I had a event which rebooted my Z-Net via a script. It has not run for months, as there never was a problem since upgrading to .190, but recently I had problems with my ISP, and my Z-Net stayed red. So I run the script, but it does not reboot. SO I guess the command does not work any more ? Is there any other way ? (I used to use a LightwaveRF on/off module to be able to power cycle, but I need that somewhere else)
This is the script I used to run (I checked the IP is correct):
Dim IP as String = "192.168.1.113" Dim URLStr as String = "" Dim ReplyStr as String = "" Sub Main(parm as object) URLStr = "http://" & IP & "/Main/Reboot.php" ReplyStr = hs.urlaction(URLStr,"GET","","") End Sub
