I've read that some of you are using USB over ethernet hubs. What has your experience been with them, and what are you using? Has anyone used them with USB sound cards? I'm considering adding this to my setup, but since HS is virtualized I don't want to use a real USB hub (stability issues). I'm trying to determine if I can reliably run multiple USB sound cards with a USB over Ethernet hub for zoned audio. My other option is to use a dedicated Windows PC just for the audio (JRMC) which I would prefer not to do.
Virtualization and USB over Ethernet devices
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.Tags: None
I use a Belkin ethernet-usb adapter. It's got 2 RFXCom interfaces, a USBUIRT and a no-name sound card for Homeseer anouncements connected to it. These are all pretty reliable, although the sound card sometimes seems to disconnect for no apparent reason.
I did try to use 2 hubs with 2 extra sound blaster cards to use as zones with JRMC, but I couldn't get them to work reliably. In the end I decided that a cheap DLNA capable receiver in each zone was a simpler answer, with one usb sound card output direct from the JRMC PC for the main zone.
Could you not use the USB ports on the host computer and pass them to the virtual Homeseer PC?
Originally posted by billt View PostCould you not use the USB ports on the host computer and pass them to the virtual Homeseer PC?HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Originally posted by reidfo View PostThanks for the input. My experience with USB passthrough has not been all that great in the past. I've had devices disconnect, and devices come up in different locations after a reboot (i.e. virtual COM port was COM3, now it's COM4).
With VMWare Workstation, all my USB problems went away when I gave VMWare the USB device IDs to always passthrough/connect to each virtual host I wanted them on... but I'm also not doing anything as USB intensive as running a few soundcards.
