I am attempting to use the plug-in to connect to the Elk-M1 using an ethernet connection. I am able to connect successfully using ElkRP. but cannot get the HS plug-in to connect. I am including an excerpt of my log below in the hopes that someone can provide some guidance as to how to resolve this issue.
Update: Problem solved...I did not have the non-secure port enabled. After enabling I am now able to connect to the M1.
11/10/2005 10:54:41 PM ~!~Info~!~Interface ELK-M1 is running as a trial, 30 days remaining. 11/10/2005 10:54:41 PM ~!~Info~!~Initializing Plug-in: ELK-M1 11/10/2005 10:54:41 PM ~!~Elk-M1 Plug-in Info~!~Register callback completed 11/10/2005 10:54:41 PM ~!~COM Plugin~!~Calling InitIO 11/10/2005 10:54:43 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:54:48 PM ~!~COM Plugin Info~!~Elk-M1 Ethernet Initializing... 11/10/2005 10:54:48 PM ~!~COM Plugin~!~InitIO error: Wrong protocol or connection state for the requested transaction or request 11/10/2005 10:54:48 PM ~!~COM Plugin Error~!~Error initializing Custom Interface: Wrong protocol or connection state for the requested transaction or request 11/10/2005 10:54:48 PM ~!~Error~!~Initializing interface: ELK-M1->Wrong protocol or connection state for the requested transaction or request 11/10/2005 10:54:48 PM ~!~Info~!~Done initializing plug-in ELK-M1 11/10/2005 10:54:48 PM ~!~Info~!~Local IP address is: 192.168.1.106 11/10/2005 10:54:48 PM ~!~Info~!~Web Server thread started on port 80 11/10/2005 10:54:48 PM ~!~Startup~!~Initializing text to speech 11/10/2005 10:54:49 PM ~!~Info~!~Listening for remote speaker connections on port 8742 11/10/2005 10:54:49 PM ~!~Startup~!~Start remoting 11/10/2005 10:54:49 PM ~!~Startup~!~Start event processing 11/10/2005 10:54:49 PM ~!~Info~!~This version of HomeSeer is not registered and is running as a trial, 30 days remaining. 11/10/2005 10:54:49 PM ~!~Startup~!~Running startup script 11/10/2005 10:54:50 PM ~!~Startup~!~Scripting is OK 11/10/2005 10:54:50 PM ~!~Info~!~Done with scripting 11/10/2005 10:54:50 PM ~!~Startup~!~Starting scheduler 11/10/2005 10:54:50 PM ~!~Startup~!~Start up complete. 11/10/2005 10:54:50 PM ~!~Info~!~Web Server authorized local login successful from: 127.0.0.1 User: default 11/10/2005 10:54:56 PM ~!~X10 Received~!~B1 (?) B On 11/10/2005 10:54:56 PM ~!~X10 Received~!~C1 (Study Study Light) C On 11/10/2005 10:55:03 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:55:13 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:55:17 PM ~!~X10 Received~!~B1 (?) B On 11/10/2005 10:55:17 PM ~!~X10 Received~!~C1 (Study Study Light) C On 11/10/2005 10:55:23 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:55:33 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:55:43 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:55:53 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:56:03 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:56:09 PM ~!~Elk-M1~!~Comm Method changed to Ethernet 11/10/2005 10:56:09 PM ~!~Elk-M1~!~Dialog load : INI = True 11/10/2005 10:56:13 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:56:23 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:56:33 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170 11/10/2005 10:56:43 PM ~!~Elk-M1~!~Connecting to IP 192.168.1.170
