I installed a Rainforest Eagle SmartMeter Gateway energy monitor and it is a great little device. Unfortunately, a plugin for Homeseer does not exist.
http://rainforestautomation.com/rfa-z109-eagle/
http://www.amazon.com/Rainforest-EAG...inforest+eagle
The unit does not require a connection (CT Clamps, etc.) to the power service coming into the house, but instead pulls data directly off of your Smart Meter. It can also pull your current $/kWh billing rate from the meter if your utility supports it (mine does not appear to at this time). It supports "From Grid" and "To Grid" if you are doing solar generation. It communicates with the Smart Meter using Zigbee, and connects to your network over Ethernet. The Eagle is fully supported and approved by many Utility providers, and since it communicates directly with your power meter, it requires authorization from your Utility provider. SCE is my provider, and all I did was login to my account page, go to the device management tab and register the device with the MAC address and ID number. Took all of about 5 minutes. You can check here to see if your utility provider supports the Eagle.
http://rainforestautomation.com/supported-utilities/
There also seems to be a mature API available.
http://rainforestautomation.com/wp-c...ST_API-1.1.pdf
http://rainforestautomation.com/developer/
It would be great to have a plug-in that could read values from the Eagle into HS3 devices and populate the HS3 Energy Database. Are there any developers that are interested in creating this plug-in?
I had suggested in another forum that if there were enough of us interested in using this device in their Homeseer environment, maybe we could each chip in a few bucks and buy one for the developer that takes on the project. In any case, if anyone wants to know more about the device, post in this thread and I will try and answer any questions that I can.
