New Insteon Motion Sensor II...beta support available in the Updater
    Motion Sensor II registering in log but device not updating and events not triggering
    Hi Mark
    I am running version 3.0.6.33 of the Insteon plug in. The motion sensor II is giving me a problem I have not seen before with other devices.
    The occupancy sensor when triggered shows up in the HS3 log. However, the device on the home page is not updated and events are not triggered based on the occupancy sensor changing to Motion or 100.
    I have reset the motion sensor and re-programmed for homeseer. I have pasted the .ini entry below:
    [Device 61]
    DatabaseDelta=25
    DeviceID=4A.65.DF
    DeviceLocation=Back Courtyard
    DeviceName=Entry Fence Motion Sensor 2
    DeviceType=1016
    EEValues=Mode=32,PIRDelay=3,HeartbeatInterval=16,LowBatteryL evel=133,TempCalibration=5,PowerSource=Battery,OpFlags2=32,L EDBrightness=0
    FailedInteractions=23
    FirmwareVer=46
    HopData=10144,9340,688,116
    LastContact=4/27/2018 10:36:30 PM
    Link 1=EA 01 41 05 23 00 00 01 1
    Link 2=E2 02 41 05 23 00 00 02 2
    Link 3=E2 03 41 05 23 00 00 03 3
    Link 4=E2 04 41 05 23 00 00 04 4
    Link 5=E2 10 41 05 23 00 00 10 5
    Link 6=E2 0B 41 05 23 00 00 0B 6
    Link 7=E2 01 41 05 23 00 00 01 7
    LinksDownloaded=1
    NumLinks=7
    PollingInterval=0
    Protocol=3
    RecentDatabaseDelta=25
    TotalInteractions=159
    Here is an example of a log entry that doesn't register as a device change or a trigger:
    May-06 3:22:23 AM Insteon Received Back Courtyard Entry Fence Motion Sensor 2 Occupancy Sensor: (4A.65.DF) Go ON
    I do note that the heartbeat/temperature entries do update in the device page.
    Lastly, I have found that the Night Only triggers all the time and not just during night time. That could be because my dusk/dawn sensor is not updating. Perhaps I have a bad piece of hardware on top of the issues mentioned above.
    Please let me know if you have any suggestions.
    Kind regards
    Jono
      Jono,
      with detailed logging enabled, do you see the plugin trying to set the hs device value after Insteon Received msgs? Please post a detailed log snippet of the plugin processing the ON
      what trigger are you using with the MS II?
      the night mode gets set after its programmed in to the MS with a received On msg. you can force programming, by pressing the set btn on the ms and you should see the programming in the log.
      any chance you are running out of link space in your plm? have you used the 'display interface links' to see where you're at? maybe the plm isn't getting the links required
      Mark
      HS3 Pro 4.2.19.5
        Originally posted by mnsandler View Post
        Jono,
        Hi Mark, thanks for the fast response. I have 805 links, which I don't think is too many. I have tried just about all of the triggers including the "changes and becomes" and "value set to". I have also tried "value set and greater than". None of them seem to trigger.
        I have set the logging to detailed and will report on that as soon as I get an ON trigger.
        As for the Night Only, I have done the proper programming, but the hardware seems to send the signals day and night. I don't know if that means the hardware is bad, or there is something in the latest software version that isn't programming the hardware properly. My guess is it is the hardware, otherwise other message board members would be reporting the same issue.
        Thank you for your time and interest.
        Jono
          have you tried the insteon special triggers?
          what fw ver is the plugin reporting for your MS II?
          Mark
          HS3 Pro 4.2.19.5
            Jono
            Here is the detailing logging of the Motion Sensor II ON:
            (reads bottom up)
            May-06 12:02:12 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 11 00 01 CB 06 00 Debouncing repeat.
            May-06 12:02:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 11 00 01 CB 06 00
            May-06 12:02:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 02 01 CB 11 01
            May-06 12:02:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 01 01 CB 11 01
            May-06 12:02:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 00 01 CB 11 01 Debouncing repeat.
            May-06 12:02:10 PM Insteon Setting status and value for device 4A.65.DF:1. Old status:100 Old Value:100, New Status:2 New Value:100
            May-06 12:02:10 PM Insteon ProcessGroupBroadcast: Device Back Courtyard Entry Fence Motion Sensor 2 (4A.65.DF) is group broadcast source (tgt group/button:1) sending cmd 11
            May-06 12:02:10 PM Insteon Received Back Courtyard Entry Fence Motion Sensor 2 Occupancy Sensor: (4A.65.DF) Go ON
            May-06 12:02:10 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 00 01 CB 11 01
              Device Type: Motion Sensor II
              Firmware Version: 46
              I will try the Insteon special triggers (for receiving and On Command) and report back.
              thanks
                thanks
                The Insteon Special Triggers method seems to be working! It fires the event. Log is here:
                May-06 12:16:22 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 11 00 01 CB 06 00 Debouncing repeat.
                May-06 12:16:21 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 11 00 01 CB 06 00
                May-06 12:16:21 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 02 01 CB 11 01
                May-06 12:16:21 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 01 01 CB 11 01
                May-06 12:16:20 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 00 01 CB 11 01 Debouncing repeat.
                May-06 12:16:20 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 65 DF 00 00 01 C3 11 01 Debouncing repeat.
                May-06 12:16:20 PM Insteon Setting status and value for device 4A.65.DF:1. Old status:100 Old Value:100, New Status:2 New Value:100
                May-06 12:16:20 PM Insteon ProcessGroupBroadcast: Device Back Courtyard Entry Fence Motion Sensor 2 (4A.65.DF) is group broadcast source (tgt group/button:1) sending cmd 11
                May-06 12:16:20 PM Insteon Received Back Courtyard Entry Fence Motion Sensor 2 Occupancy Sensor: (4A.65.DF) Go ON
                May-06 12:16:20 PM Event Remove Delayed Device Action Removed event: Delayed Actions Any Back Yard Motion Sensor Activated (Delayed Action)
                May-06 12:16:20 PM Event Event Trigger "Outdoor Motion Sensors Virtual Any Back Yard Motion Sensor On turns Off in 10 seconds"
                May-06 12:16:20 PM Device Control Device: Virtual Back Courtyard Any Back Yard Motion Sensor Activated to On (100)
                May-06 12:16:20 PM Event Event Trigger "Outdoor Motion Sensors Back Courtyard Fence MS II turns Any Back Yard Motion Sensor On"
                  in this scenario the hs triggers probably won't fire because the device values doesn't actually change. it was 100 and then set 100
                  Mark
                  HS3 Pro 4.2.19.5
                    Jono,
                    for the night only mode, did you capture a log showing the settings getting updated after an receiving an ON?
                    Mark
                    HS3 Pro 4.2.19.5
                      Jono,
                      I got this:
                      Motion Sensor 4A.65.DF settings programmed successfully.
                      But it still triggers even though it is daytime
                        I will have the event set the MS II back to zero (no motion) and see if that makes a difference
                            Jono,
                            you should be receiving Off msgs.
                            but you can use hs.setdevicevalue in a script to change the value; this this shouldn't be necessary
                            Mark
                            HS3 Pro 4.2.19.5
                              Temperature inaccurate when heartbeat received?
                              Apologies if this is a duplicate... I'm using 3.0.6.35 and I received my new motion sensor II's yesterday. Today I noticed a problem with temperature... From my log:
                              <table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri1" colspan="1" align="left">
                              </td><td class="LogType1" colspan="3" align="left"> Insteon </td><td class="LogEntry1" colspan="8" align="left"> Setting value for device 4A.7B.A7:21. Old Value:14, New Value: 5 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Setting value for device 4A.7B.A7:20. Old Value:3, New Value: 4 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri1" colspan="1" align="left">
                              </td><td class="LogType1" colspan="3" align="left"> Insteon </td><td class="LogEntry1" colspan="8" align="left"> Setting value for device 4A.7B.A7:11. Old Value:69.7, New Value: 54.6 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Setting value for device 4A.7B.A7:4. Old Value:100, New Value: 0 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri1" colspan="1" align="left">
                              </td><td class="LogType1" colspan="3" align="left"> Insteon </td><td class="LogEntry1" colspan="8" align="left"> Setting value for device 4A.7B.A7:4. Old Value:0, New Value: 100 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Device House New Lamp Module (4A.7B.A7) sent a heartbeat: Battery=Full, Temp=54.6, Light=5 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:37 </td><td class="LogPri1" colspan="1" align="left">
                              </td><td class="LogType1" colspan="3" align="left"> Insteon </td><td class="LogEntry1" colspan="8" align="left"> Received STX 0x50 (Raw Insteon Rec):4A 7B A7 EB 05 0B CF 0C 6E </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:07 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Saved ini file. msecs=26 </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:03 </td><td class="LogPri1" colspan="1" align="left">
                              </td><td class="LogType1" colspan="3" align="left"> Insteon </td><td class="LogEntry1" colspan="8" align="left"> ..finished saving comm stats. </td></tr> </tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left"> May-24 15:37:03 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Saving comm stats... </td></tr></tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr><td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left">May-24 15:37:37 </td><td class="LogPri0" colspan="1" align="left">
                              </td><td class="LogType0" colspan="3" align="left"> Insteon </td><td class="LogEntry0" colspan="8" align="left"> Received STX 0x50 (Raw Insteon Rec):4A 7B A7 EB 05 0B CF 0C 6E Debouncing repeat.
                              Darn - sorry about the font!
                                May-24 15:37:37
                                Insteon Setting value for device 4A.7B.A7:21. Old Value:14, New Value: 5
                                May-24 15:37:37
                                Insteon Setting value for device 4A.7B.A7:20. Old Value:3, New Value: 4
                                May-24 15:37:37
                                Insteon Setting value for device 4A.7B.A7:11. Old Value:69.7, New Value: 54.6
                                May-24 15:37:37
                                Insteon Setting value for device 4A.7B.A7:4. Old Value:100, New Value: 0
                                May-24 15:37:37
                                Insteon Setting value for device 4A.7B.A7:4. Old Value:0, New Value: 100
                                May-24 15:37:37
                                Insteon Device House New Lamp Module (4A.7B.A7) sent a heartbeat: Battery=Full, Temp=54.6, Light=5
                                May-24 15:37:37
                                Insteon Received STX 0x50 (Raw Insteon Rec):4A 7B A7 EB 05 0B CF 0C 6E
                                May-24 15:37:07
                                Insteon Saved ini file. msecs=26
                                May-24 15:37:03
                                Insteon ..finished saving comm stats.
                                May-24 15:37:03
                                Insteon Saving comm stats...
                                May-24 15:37:37
                                Insteon Received STX 0x50 (Raw Insteon Rec):4A 7B A7 EB 05 0B CF 0C 6E Debouncing repeat.
                                Can you tell me what the concern is?
                                Mark
                                HS3 Pro 4.2.19.5
