How would I log changing device values?
    HI folks!
    I want to log changing light/lux/luminance values in one of my devices/sensors.
    Possibly every hour to start, just to get a handle on actual values through the day.
    So basically I would want to capture day, time and device/lux value
    (basically it would then be usable to track changing values on *any* device, not just light)
    Can anyone suggest a way to do this?
    It depends on how much data you want to store and for how long. If you want many days or months, then you could write to a database - ie SQLite. Many plugins use a database for data storage. If you want only a day or two, then review the data and start over, you could use a script and write to a file on linux. You could even use a Linux bash script to move the file with the collected data to a "backup file" named with the day's date to review later. If you want to review the data within homeseer, you could write the data to a virtual device's string. Which you could overwrite however often you desire with an event and a script. I do this to review a 24 hour summary of how long each of my HVAC zones run each day.
    Bruce
      Originally posted by Otto-mation View Post
      HI folks!
      There are two very good, but different device graphing utilities. I use them both. Jon's is infinitely more configurable, making it a little more challenging to set up. Shill's Device History is a snap to configure and works very well.
      Jon00's Database Charting Utility
      SKWare's Device History plug-in
      If you are running Linux you will need to see what plug-ins are supported. I think Device History is supported.
        I agree with Randy, there are good plugins to do this.
        As he stated in his last sentence, if you are running Linux it takes more work. I am running the hometroller Z, which is Linux based and can only use 5 plugins, so I am always looking for scripts and other ways to
        do things. I have my 5 plugins, so I can't add anymore.
        Bruce
          Thanks for these suggestions. Very helpful.
          I will start by writing to a virtual device's string to see if that's sufficient for me, and then take it from there.
            Thanks Randy - since I'm using a Zee, I will try the Device History plugin after I give the virtual device string method a try.
