HomeSeer Mobile is a new FREE mobile app that's designed to work with HomeSeer HS3-based systems including the following:
This first beta release is for Android mobile devices. An IOS version will be available shortly. As with any beta release, bugs and other issues may be encountered and these may impact the stability of your HomeSeer system. If this is not acceptable, you should wait for the final release version.
The App supports Android version 5 and later (Lollipop).
Features
Getting Started
To get started, you must have HS3 version 3.0.0.458 or later. You can grab that from here:
https://forums.homeseer.com/showthread.php?t=181241
You will need to install from the Google Play store: https://play.google.com/store/apps/d...mobile.android
We have a knowledge base with some documentation here:
https://helpdesk.homeseer.com/catego...omeseer-mobile
You can also get to this knowledge base from the help menu in the app.
Reporting Bugs / Issues
If you run into any crashes, you will be prompted with a dialog to submit crash info, please submit this! It will contain valuable information.
If you find a non-crash bug or there is an enhancement you would like to request, from within HomeSeer Mobile select the menu icon (upper left corner) then the "Send Feedback" item. This will start an email. Fill it in and submit. You can include screen shots as attachments. This will create a ticket in our bug tracking system.
You can also post any issue to this forum so others can review, but an issue will not get addressed unless it is in our bug tracker.
Here are a list of known issues, so please don't report these!
We are looking for feedback on how well the app displays plugin devices. Thanks in advance to everyone who participates in this beta. Please be sure to submit your bugs, issues or suggestions using the email function in the app or by posting to this thread.
- HS3, HS3PRO & HS3-Pi Software
- HomeTroller Zee S2
- HomeTroller-SEL (standard & PRO versions)
- HomeTroller S6 (standard & PRO versions)
Features
- Customizable dashboard. Add any device, resize, control items to show. Multiple dashboards are supported
- Device list. Shows all devices, supports sorting and controlling any device and adding devices to the dashboard.
- Event list. Show all events, run an event, add to the dashboard.
- Camera list. Shows the latest snapshot from all cameras. Click on a camera to display larger real time view and pan/tilt controls. The camera list is auto updated every 10 seconds.
- Supports log in from MyHS and local IP.
Getting Started
- Adding an event widget to the dashboard my insert the widget under other widgets. To workaround, manually move other widgets to find.
- When reducing a widget on the dashboard to just an icon, the text "Information Line" will display. For now, keep the name checked and clear it out.
- On the device list, if you search with the search box and then leave the screen, the keyboard will pop back up every time you go to that screen. Simply click <- at the top of the screen to clear the search.
- Landscape view is not yet supported
- If you add a primary device to a dashboard widget and then click on the device to get info, you will see info for the root device, not the child device as expected.
- Camera views on the dashboard are not updating yet. But you can click on a camera to see a live view.
