I hope someone can help with this... Feel free to rip the code apart. I am new to to VB.NET :-)
I have some code that runs fine and does as intended and then after an unspecified amount of time (this example took 50 mins based on log time) or tries it goes throwing the error below. Here is the Code, then the Log when it is fine and the Log when it tanks. Rebooting HS3Pro server fixes it temporarily.
And it wasn't doing this all along, this just started a few days ago. Granted some code changes were made but I am stumped.
Here is the log when it is AOK
Jul-18 7:40:09 PM Event Event Trigger "System LCARSUnlock"
Jul-18 7:39:19 PM Event Event Trigger "System LCARSUnlock"
Jul-18 7:38:59 PM Event Event Trigger "System HSTouch-WaterWorld-ClientSetName"
Jul-18 7:38:59 PM HSTouch Server This client was already connected, removing old connection.
Jul-18 7:38:59 PM Speaker Speaker host added, Name: Automation-SVR Instance: WaterWorld IP address: 10.0.0.37
Jul-18 7:38:59 PM HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.17
Jul-18 7:38:59 PM HSTouch Server Client WaterWorld (10.0.0.37/3270) named WaterWorld has CONNECTED.
Jul-18 7:38:58 PM HSTouch Server Opening connection from:10.0.0.37/3270
Jul-18 7:38:56 PM Event Event Trigger "System HSTouch-LCARS_MAIN-ClientSetName"
Jul-18 7:38:56 PM Speaker Speaker host added, Name: Automation-SVR Instance: LCARS_MAIN IP address: 10.0.0.31
Jul-18 7:38:56 PM HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.17
Jul-18 7:38:56 PM HSTouch Server Client LCARS_MAIN (10.0.0.31/50646) named LCARS_MAIN has CONNECTED.
Jul-18 7:38:55 PM HSTouch Server Opening connection from:10.0.0.31/50646
Jul-18 7:38:46 PM HSTouch Server Client WaterWorld named WaterWorld has DISCONNECTED.
Jul-18 7:38:46 PM ASR Speaker Client speech recognition stopped
Jul-18 7:38:46 PM Speaker Speaker host disconnected, Name: AUTOMATION-SVR IP address: 10.0.0.37
Jul-18 7:38:46 PM HSTouch Server Client WaterWorld:WaterWorld (10.0.0.37/3192) has raised LineDisconnected or was forced closed.
Jul-18 7:38:45 PM EnvisaLink DEBUG CommandAcknowledge 000
Jul-18 7:38:45 PM EnvisaLink DEBUG Request: Poll
Jul-18 7:38:39 PM HSTouch Server Client LCARS_MAIN named LCARS_MAIN has DISCONNECTED.
Jul-18 7:38:39 PM ASR Speaker Client speech recognition stopped
Jul-18 7:38:39 PM Speaker Speaker host disconnected, Name: AUTOMATION-SVR IP address: 10.0.0.31
Jul-18 7:38:39 PM HSTouch Server Client LCARS_MAIN:LCARS_MAIN (10.0.0.31/50644) has raised LineDisconnected or was forced closed.
Jul-18 7:38:24 PM Event Event Trigger "System HSTouch-LCARS_MAIN-ClientSetName"
Jul-18 7:38:24 PM Speaker Speaker host added, Name: Automation-SVR Instance: LCARS_MAIN IP address: 10.0.0.31
Here it is when it goes south.
Jul-18 8:29:59 PM Event Event Trigger "System HSTouch-WaterWorld-ClientSetName"
Jul-18 8:29:58 PM Error Calling HSEvent in plugin tenScripting, Instance T081408:Object reference not set to an instance of an object.
Jul-18 8:29:34 PM Error 3 Running script LavallieHA.vb :Exception has been thrown by the target of an invocation.->Does entry point Main exist in script? at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Obj ect obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Scheduler.clsRunVBNetScript.ExecuteScript()
Jul-18 8:28:45 PM EnvisaLink DEBUG CommandAcknowledge 000
Jul-18 8:28:45 PM EnvisaLink DEBUG Request: Poll
Jul-18 8:28:27 PM Event Event Trigger "System LCARSUnlock-LCARS_MAIN"
Jul-18 8:28:27 PM Event Event System LCARSUnlock-LCARS_MAIN triggered by the event page 'Run' button.
Jul-18 8:28:00 PM Event Event Trigger "System LCARSUnlock-LCARS_MAIN"
Jul-18 8:28:00 PM Event Event System LCARSUnlock-LCARS_MAIN triggered by the event page 'Run' button.
Jul-18 8:27:46 PM Event Event Trigger "System LCARSUnlock-LCARS_MAIN"
Jul-18 8:27:46 PM Event Event System LCARSUnlock-LCARS_MAIN triggered by the event page 'Run' button.
Jul-18 8:26:45 PM EnvisaLink DEBUG CommandAcknowledge 000
Jul-18 8:26:45 PM EnvisaLink DEBUG Request: Poll
Jul-18 8:26:39 PM Event Event Trigger "System LCARSUnlock-WaterWorld"
System as it is now - Will eventually get it in my Signature.....
HomeSeer Version: HS3 Pro Edition 3.0.0.435 (Windows)
HomeSeer: Is Registered
Operating System: Microsoft Windows 7 Professional - Work Station
HSTouch clients are 3.0.0.55 on Win10 Pro Tablets and one Win7 Pro x64 PC
-Nac
Public Sub Main(pParms As Object) Dim SecStatus As Boolean Dim P0 As String Dim P1 As String 'For Y = 0 To UBound(pParms) ' hs.WriteLog("DebugCode", pParms(Y)) 'Next SecStatus = False P0 = pParms(0).ToString() P1 = pParms(1).ToString() If P1.Length <= 0 Then hs.PlayWavFile("C:\Program Files (x86)\HomeSeer HS3\Wave\LCARSDenied.wav", "Automation-SVR:" & P0, False) hs.WriteLog("Debug", "No Code entered") Exit Sub End If If P1 = "2264" Then SecStatus = True hs.TriggerEvent("LCARSUnlock-" & P0) 'Three Events cause 3 possible devices could trigger it. Only want the event to fire for the device that triggered it. Else hs.PlayWavFile("C:\Program Files (x86)\HomeSeer HS3\Wave\LCARSDenied.wav", "Automation-SVR:" & P0, False) hs.WriteLog("Debug", "Code is wrong :" & P1) End If End Sub
-Nac
