I keep getting the follow errors in the log. I see others are getting them also. My network is fine, so must be something with the board?
May-07 20:06:49 EnvisaLinkAdemco INFO Password OK
May-07 20:06:49 EnvisaLinkAdemco INFO Reconnection OK
May-07 20:06:49 EnvisaLinkAdemco INFO Trying to reconnect to: 192.168.3.201:4025
May-07 20:06:38 EnvisaLinkAdemco INFO Connection Lost, will try to reconnect in 10 seconds
May-07 20:06:38 EnvisaLinkAdemco ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
May-07 20:06:38 EnvisaLinkAdemco INFO Reconnection OK
May-07 20:06:38 EnvisaLinkAdemco INFO Trying to reconnect to: 192.168.3.201:4025
May-07 20:06:27 EnvisaLinkAdemco INFO Connection Lost, will try to reconnect in 10 seconds
May-07 20:06:27 EnvisaLinkAdemco ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
May-07 20:02:47 EnvisaLinkAdemco INFO Zone 8 status change: Closed
May-07 20:02:28 EnvisaLinkAdemco INFO Zone 8 status change: Opened
I am hesitant to set the polling to 30 as I have triggers based open zone. I would, however, like to stop the motion detectors from logging. I went into the node for the motion detectors and set "Do not log commands for this device" thinking that would do it, but it does not. Can I turn off logging just for the motion detectors?
