I've been using HS3 for a while now and I have been keeping it simple. I have only been controlling simple z-wave switches and outlets. Normal daily use lights/outlets and typical holiday lighting, etc. I got a little more detailed and added control/notification of my home alarm using the Vista Alarm plug-in and added a little bit of simple control through Google Home and IFTTT.
So, recently, I decided I wanted to go a little deeper and start doing a little experimentation with implementing RPi's and scripting into my home automation. I created a working garage door opener using an RPi that I activate via a URL. I created a virtual device that will act as the controller for the garage door opener and then created an event in HS3 that sends a direct script using GetURL. This event is triggered when the value of the virtual device changes.
This is working, but not quite as refined as I would like. The virtual device has an open and close control button (even though they both trigger the exact same event) so this kind of confuses my wife sometimes (not sure why).
I was thinking I might create some type of virtual device, but where it only had one control button that was "Operate garage door" or something. Then the status icon could be changed by whatever the garage door sensor state is in (open/close). But, when I had an event that was triggered by the change in the garage door sensor that then changed the status of the garage door opener virtual device, it kind of created a nice, but unwanted, loop!
I'm trying to use this whole process as a learning/teaching process, so that's why I'm getting a little more detailed into the controls. I'm sure I'm over complicating this and I don't really know exactly what I want, but thought some of you experts would have some advice.
Corey
Corey
