2 seconds is simply not enough time to poll a thermostat and get all of the data. If you didnt have that section in your settings.ini before, then it must be defaulting to 2 seconds.
Are you shutting down HS before adding that line?
Also, are you sure you only have one [Z-Wave] entry in your settings.ini?
Post your Z-Wave section here to see if we can spot anything.
