In this build I have added device control for all devices created by the plugin.
When you update to BLAB8SS 2.0.2.0 for HomeSeer 3, you will need to do the following:
1. Install BLAB8SS 2.0.2.0 from the HS3 updater
2. Delete all previous BLAB8SS devices from HomeSeer 3 (you can sort by device type to make it easier if you have renamed them)
3. Shutdown HS3
4. Edit the hspi_BLAB8SS.ini file and change the following entries:
initialDevicesCreated=false
initialAllSpeakersDevicesCreated=false
5. Save the ini file
6. Restart HS3
You should have On/Off controls now for all BLAB8SS devices.
3. Shutdown HS3
6. Restart HS3
