I have had my CT30 installed for a few months. It works good with Homeseer. My problem is that the CT30 will tell the furnace to turn on, then a minute or 2 will tell it to turn off, then a moment after that, tell it to turn on again.
The big problem with this is that the ingniter goes thru an extra cycle each time, so it is going to wear out prematurely.
Obviously this is not normal. I am wondering if I got a defective one. Anyone else notice this behavior?
Also - I do have the setting for the threshold (not sure what it is called) at the stock 1.5 degrees. I tried 2 degrees, but it acted the same.
