2GIG Temperature Wrong
    Hi All
    Got my 2gig thermostat installed and hooked up to HS and HSTouch. Can now control heat setpoint up and down and set hold.
    However, the current Temperature displayed is wrong. I go upstairs and the unit says the current temp is 65, but in HS, it says 60.5. Anyone got the current temperature reporting properly, or any suggestions how to fix?
    It's a real shame it doesn't report the Heat Mode at all
    Regards
    mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    did you run the thermostat plugin. set the 2gig on the device status to poll every 1 if you have t. c on 24 v. i do not have issues and gives me a status right away. you may want to consider blblade.
    aldo
      Originally posted by mark_anderson_us View Post
      Hi All
      Regards
      mark
      What version of HS are you running?
        I'm on 2.5.0.20
        I have with zwave thermostat and blstat pluig-in. both give same readings. Unfortunately, I'm on battery only. I could run 24v from a transformer to power it if I really needed to (easy cable run)
        Regards
        Mark
        USB UIRT
        2GIG Thermostat
        BLUPS
        UltraLog (SQL2008)
        Jon00 Plugins
        Global Cache IP2IR
        Foscam FI8918W
          Definitely run with the C cable. I have done it for both my thermostats, it works great. Do you have this turned on "Wave Thermostats ZWave Thermostats Status N/A HSPI_ZWAVETHERM.DLL N/A Interface OK"
          Aldo
            Hi Aldo,
            A bit puzzled by the above. Is this a setting somewhere I should be looking for?
            Regards
            Mark
            USB UIRT
            2GIG Thermostat
            BLUPS
            UltraLog (SQL2008)
            Jon00 Plugins
            Global Cache IP2IR
            Foscam FI8918W
              You will find it by selecting Setup, Interfaces and Wave Thermostats ZWave plugin. Please turn it on.
              Aldo
