Originally posted by Rotech
View Post
3M-50 WiFi Thermostat plug-in available to test
Keep in mind that for those of you currently using the plugin the hold mode device does show on/off status. Until the next release though you'll need to manually turn off hold (or do it in an event) when HS changes the setpoint.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Reidfo, if the stat is changed manually, will HS know abouts it's change at the moment or when it's polls?Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by Rotech View PostReidfo, if the stat is changed manually, will HS know abouts it's change at the moment or when it's polls?HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Originally posted by reidfo View PostI'm going to change the plugin behavior so that it does not automatically set hold when the setpoint is changed. This will let you decide how you want to use the hold feature.
I actually have the release version ready and I'm just waiting for Mark to get back to me with some details on getting it into the store. If it's not there by the weekend I'll upload another beta that includes the new hold functionality.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Ok, I decided that just in case this doesn't make it into the updater this week I'll post a final beta. It expires on 4/1/2012 and is considered the release candidate. It adds the new hold behavior, a help page, and more bug fixes.
The new hold mode means you now have a configuration option to tell HomeSeer whether or not to set Hold mode to On when the setpoint is changed. This is a global setting, and I think it will accommodate users who want HomeSeer to control every aspect of the thermostat as well as those who want the thermostat programs to be in control.
See the top post for the download link.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
A couple days ago I installed beta5 to see what the plugin looked like. I hadn't actually installed a thermostat yet. Tonight I stopped HomeSeer to uninstall beta5. After uninstalling beta5 I restarted HomeSeer and the following error was displayed when HomeSeer attempted to start. HomeSeer was unable to start. I restored a backup of the HomeSeer folder and HomeSeer was able to start, but two of my plugins were unable to start. They were returning an interface error and complaining about their license being expired in the HomeSeer log file. The affected plugins were WAFNetCallerID script and the SageTV InControl plugin. I entered the license info for both plugins and everything seems to have returned to normal. I'm running HomeSeer 2.5.0.23 on Windows XP SP3.
I am running the beta version 1.0.3 and have checked the box to prevent "phoning home". However, the thermostats are still communicating with the RF cloud server.
Does the new beta fix this problem? If I recall from the RF site, the plugin may need to set the authkey to blank to shut down the phone home capability (it is not enough, despite what the RF documentation says, to set the bit on the phone home flag to zero in order to actually shut down the communications. The RF documentation is terrible, from what I can gather).
Regards.
Guest
Originally posted by regm View PostA couple days ago I installed beta5 to see what the plugin looked like. I hadn't actually installed a thermostat yet. Tonight I stopped HomeSeer to uninstall beta5. After uninstalling beta5 I restarted HomeSeer and the following error was displayed when HomeSeer attempted to start. HomeSeer was unable to start. I restored a backup of the HomeSeer folder and HomeSeer was able to start, but two of my plugins were unable to start. They were returning an interface error and complaining about their license being expired in the HomeSeer log file. The affected plugins were WAFNetCallerID script and the SageTV InControl plugin. I entered the license info for both plugins and everything seems to have returned to normal. I'm running HomeSeer 2.5.0.23 on Windows XP SP3.
Also had the same issue with scheduler.dll when upgrading from beta5 to beta6
Apologies for the dll errors guys. Run a repair install from the add/remove programs page to fix that error. The previous builds were including dlls that should not have been in there. I've sorted that out (and figure out why they kept creeping back into the installs).HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Originally posted by jwshome2 View PostI am running the beta version 1.0.3 and have checked the box to prevent "phoning home". However, the thermostats are still communicating with the RF cloud server.
Regards.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Thanks very much. Just installed beta6 and will report on how it is working.
One thing I noticed - is it possible that the plugin is changing the "Max size for event log" setting on the general setup page? Something changed that setting to '1', and the only thing I've done is to uninstall beta4 and install beta6. I also changed my logging settings in the BeakerStat plugin from 'Verbose' to 'Error'.
Not a problem - it's easy to change it back to a larger number, but I thought I should bring it up in case it is inadvertently being caused by the plugin.
Regards.
Originally posted by jwshome2 View PostOne thing I noticed - is it possible that the plugin is changing the "Max size for event log" setting on the general setup page? Something changed that setting to '1', and the only thing I've done is to uninstall beta4 and install beta6. I also changed my logging settings in the BeakerStat plugin from 'Verbose' to 'Error'.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Originally posted by reidfo View PostThe plugin will only disable the cloud service when HomeSeer starts, so if you check the box and save your settings, you'll still need to restart HomeSeer for the change to take effect. It does blank out the authkey in addition to disabling the cloud service.
