Reliable USB over IP
    I'm looking for a reliable USB over IP solution for a USB UIRT and a 433Mhz RFX receiver.
    I purchased 2 startech USB2IP server and they continually drop connection. Need power cycle the device to get the server to see them again.
    Was thinking about going this way - Silex SX-DS-4000U2 High Performance Gigabit USB Device Server - but who knows if that would be any better.
    Any advise appreciated.
    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
    I have read good things about Silex. Here today I use Digi USB Anywhere devices. I tested them with Homeseer VM's and they did work fine except for the W2C box and one audio USB card.
    My connection was:
    Homeseer VM = (NETWORK) = > Digi USB Anywhere = = > Digi 7 port USB hub = = > 2 Digi Edgeports plus whatever else was plugged into USB hub.
      I ordered the Silex it should arrive midweek, so we'll see.
      I continue to experiment with the startech units and if you connect a flash drive they stay connected for days no issues. So something about the wgl800/usb uirt is different and the startech's don't like.
      Will report back later.
        A few years ago tried the SA USB Pim over the USB to network devices I have (also have Lantronix) and ended up talking their technical folks. I could not for any reason get it to work. The techs over at SA said it was related to their USB drivers. I never pursued anymore afterwards. Over the years relating to my HS connectivity I have always had better luck with serially connected devices whether direct or virtual. That is me though.
          I just installed one of these to place my USBUIRT the in living room entertainment center, which is 30+ feet from my HS machine. I used a home run of Cat6 STP and so far it's working great! Note that this is a point-to-point solution and does not run over an IP network.
          http://www.monoprice.com/products/pr...seq=1&format=2
          Best regards,
          -Mark-
            I use a couple of these in my setup, one for my ZWave stick and another for a Bluetooth dongle and they have been rock solid on Windows Server 2003, 2008, 2008 R2, 2012 and Windows 7 and 8 (64bit).
            http://www.maplin.co.uk/4-port-usb-g...-server-521590
            Not sure where you could source outside of the UK, but they are based on an Elite Silicon chip and if you can get hold of one, you need to have the latest firmware v2.055 from here:
            http://www.elitesilicon.com/Support.html
            Cheers,
            Jon.
              http://www.amazon.com/electronics/dp/B0024G48MY
              Looking at the Startech site, these seem to be based on the Elite Silicon chipset as well, so in theory should work the same as the ones I use sourced in the Uk.
              Good luck!
              Jon.
                I almost ordered the Gb 4 port USB server from Maplin this morning. Instead I found one here reasonably priced. I am currently moving network from Gb to all managed Gb switches using TP-Link mini managed switches and I want to give this device a try.
                Monoprice - it was $41 USD and it appears to be discontinued.
                http://www.monoprice.com/Product/?c_...mat=4#feedback
                Looks now that maybe I will order it from Maplin.
                Found one at Silex:
                http://www.silexeurope.com/en/home/p...sx-3000gb.html
                Another one which is a no name one on Amazon (with wireless).
                http://www.amazon.com/Gigabit-Networ.../dp/B006FT5WR6
                Another one here:
                http://www.digitus.info/en/products/...-hub-dn-13010/
                  The Silex SX-DS-4000U2 is waiting for me at home. Unfortunately I'm away on business and won't get to play with it until Monday night......I'll keep you posted.
                  D.
                    Thanks D. Looking forward to what you think about the Silex SX-DS-4000U2.
                      Ok......So I'm up on a vmware based Win 7 x64 machine. Running
                      Ztroller off an IP2SL connection - http://www.globalcache.com/products/itach/ip2sl-pspecs/
                      ACRF2 - IP 2 Serial - Sena LS100 - http://www.sena.com/products/device_servers/hd_lite.php
                      USB UIRT / RFXCOM 433MhZ USB to IP - Silex SX-DS-4000U2.
                      All is working good - but for a few hours only.
                      Only issue so far is the direct connected current cost envi - it's fighting as usual....
                        I should have said the silex was a very easy setup and I've had several devices connected to a test machine for a couple days no dropped connections. But the devices wern't doing anything either....
                          Thanks D.
                          I am curious to try a combo of a USB audio card, W2C box and a Mimo USB video monitor with local power. Last time I tried it was using the Lantronix box and it did work for the USB and W2C box; but it's been a couple of years and currently not using the Lantronix box.
                          Where did you purchase your Silex from?
                            Hold the fort...........Had to reboot Homeseer 4 time last nite/today. RFXCom on USB and ACRF@ on serial LS100 are losing there mind after a coule of hours. Seems like reseting the devices won't fix, but only a reboot of HS will resolve. Will take more exploring...
                              Latest experiments is to set both host and guest Power management such that only the monitor switches off. Particularly changed advanced power options and force USB power saving mode off. Also changed LS100 timeout delay to a VERY large number. Let's see if this helps.
