Recently a smart electricity meter is installed in my house. This meter is connected to my HomeSeer pc through serial to USB. I can read the data coming in with Putty.
The data looks like this. Every 10 sec this data is updated.
I trying to make this data available in Homeseer. The script runs fine until after the first line is read. Then I get the following error in the log: Length cannot be less then zero (see attached). The script I use is:
Can somebody point me in the right direction on how to solve this or where to start looking for an answer?
/KFM5KAIFA-METER 1-3:0.2.8(40) 0-0:1.0.0(140207214844W) 0-0:96.1.1(4530303039313030303031363435353133) 1-0:1.8.1(000029.567*kWh) 1-0:1.8.2(000025.374*kWh) 1-0:2.8.1(000000.000*kWh) 1-0:2.8.2(000000.000*kWh) 0-0:96.14.0(0002) 1-0:1.7.0(01.645*kW) 1-0:2.7.0(00.000*kW) 0-0:17.0.0(999.9*kW) 0-0:96.3.10(1) 0-0:96.7.21(00007) 0-0:96.7.9(00005) 1-0:99.97.0(1)(0-0:96.7.19)(000101000001W)(2147483647*s) 1-0:32.32.0(00000) 1-0:32.36.0(00000) 0-0:96.13.1() 0-0:96.13.0() 1-0:31.7.0(007*A) 1-0:21.7.0(01.651*kW) 1-0:22.7.0(00.000*kW) 0-1:24.1.0(003) 0-1:96.1.0(4730303136353631323034323832383133) 0-1:24.2.1(140207210000W)(00026.831*m3) 0-1:24.4.0(1) !D6BF
' place in Homeseer Startup.txt and replace X with com-port # ' hs.closecomport X ' e=hs.OpenComPort(X,"115200,N,8,1",1,"P1.vb","P1_event", "!") ' if e <> "" then ' hs.writelog "P1", "Setup error " & e ' else ' hs.writelog "P1", "Setup complete" ' end if ' Place the following in the Shutdown script ' e=hs.CloseComPort("X") ' if e<> "" then ' hs.writelog "Error closing COM1",e ' else ' hs.writelog "COM1", "Port was closed" ' end if 'Create these virtual devices in Homeseer Const CURRENT_POWER_USAGE = "E1" Const TOTAL_POWER_USAGE_T1 = "E2" Const TOTAL_POWER_USAGE_T2 = "E3" Const TARIFF_INDICATOR = "E4" Const TOTAL_GAS_USAGE = "E5" Const GAS_USAGE_UPDATE = "E6" Dim v1, v2, device_value, device_string, y, m, d, h Const DEBUG_LOG = True 'set to False when running without error Sub P1_event(data) If DEBUG_LOG Then hs.writelog("P1", "Data: " & CStr(data)) End If ' Current Power Use ' 1-0:1.7.0(0001.05*kW) If left(data, 10) = "1-0:1.7.0(" Then v1 = Split(data, "(") v2 = Split(v1(1), "*") device_value = CDbl(replace(v2(0), ".", ",")) * 1000 'device_string = device_value & "W" If DEBUG_LOG Then hs.writelog("P1", "Current Power Use: " & CStr(device_value) & " Watt") End If hs.SetDeviceString(CURRENT_POWER_USAGE, device_string) hs.SetDeviceValue(CURRENT_POWER_USAGE, device_value) hs.setDeviceLastChange("E1", now) End If End Sub
