I get a Creating connection error multiple times per day on my test box for HomeSeer, aside from that everything works really well. I'm not sure if I can just ignore this error or not when I'm ready to port my HS3 box's license over to it.
Aug-08 1:37:04 PM Info System registered with MyHomeSeer service successfully.
Aug-08 1:37:00 PM weatherXML Run between 0 23
Aug-08 1:36:44 PM Info System registered with MyHomeSeer service successfully.
Aug-08 1:36:31 PM Error Creating connection to MyHS service, there may a problem with the server or the Internet connection. The connection will be attempted again shortly.
Aug-08 1:36:00 PM weatherXML Tiggers to check: 0
Aug-08 1:36:00 PM weatherXML Check for last ran triggers
Aug-08 1:36:00 PM weatherXML Run between 0 23
Aug-08 1:35:49 PM Info System registered with MyHomeSeer service successfully.
Aug-08 1:35:20 PM Info System registered with MyHomeSeer service successfully.
It could just be an internet connection thing I suppose, I hope its not an issue with the server, everything is up to date (version wise).
Not sure what the trial version of HomeSeer does, if it does checking / registering more often and some of those requests are just timing out/failing in which case I don't have to be concerned at all?
Thanks anyone who has any ideas!
