Originally posted by integlikewhoa
View Post
Harmony plugin for Linux?
Originally posted by integlikewhoa View PostAny update on this error I'm getting?
The file is located here https://dl.dropboxusercontent.com/u/...HarmonyHub.exe
RienLast edited by Rien du Pre; October 27, 2016, 05:23 AM.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Rien du Pre View PostI 've put up a version with more logging, just for testing this error. Can you please try this one and sent me the logging during the poll
Rien
Originally posted by ZoRaC View PostAny progress on getting the plugin working on 64-bit Linux?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Rien du Pre View PostIf someone can supply met with a 64-bit Linux image, I can make it happen.
Originally posted by ZoRaC View PostRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Rien du Pre View PostI was hoping for a working (vmware) image off working 64 bit Homeseer system.
File: https://www.dropbox.com/s/ef1s7enktbogu7j/hs3.zip?dl=0
User: hs3
Password: hs3
Homeseer is installed in /usr/local/Homeseer (run "go")
Sorry that the extracted file is a bit big - I forgot to "holepunch" it before downloading it...
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Rien du Pre View PostHave you ever tried it with the standard harmonyhubcontrol_linux.exe, because in the Ubuntu image you sent me it just works.
I just did a new test and you're right, it's working now!
Had to do a "chmod +x" on the exe to get it working, but other than that it seems fine now.
Originally posted by ZoRaC View PostI tried it in august and ran into the problem of the exe being 32-bit only. I've been watching this thread (http://board.homeseer.com/showpost.p...4&postcount=63) for any follow up, but haven't seen any news there or any information that the plugin now is 64-bit compatible.
Now it should work on all platforms supported bij HomeSeer
One question for the Linux guru's. How can I solve the fact that every Linux user have to do a "chmod +x"?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Rien du Pre View PostOne question for the Linux guru's. How can I solve the fact that every Linux user have to do a "chmod +x"?
http://homeseer.com/support/homeseer/HS3/SDK/copy.htm
The file is an EXE file and needs to be registered by calling the EXE file with the switch /regserver.
Another option is to include a script that simply performs the "chmod +x", using bit 8, perhaps?
Originally posted by ZoRaC View PostI'm not familiar with the plugin-development of Homeseer, but perhaps you need the last bit in the install-file to be 18 instead of 16 for that file?
I would expect that on Linux, the installer would do a "chmod +x" on a file with that bit set?
ThanksRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by jimbo333 View PostAny updates on the chmod +x in the install script? I am running HomeSeer from a docker container, running the chmod +x is not really possible from the container like that, but it appears like its not executable in the current installer.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
