Standing by... not there yet for me.
Feature requests
There it is (and it is awesome! ), but that leads me to another featurerequest: Set up root/child devices, and prefix a device name with the hub name
It's hard to tell the different devices from each other now...
Code:'Associating devices rootDevice.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Parent_Root rootDevice.AssociatedDevice_Add(hs, childDevice1Ref) rootDevice.AssociatedDevice_Add(hs, childDevice2Ref) childDevice1.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Child childDevice1.AssociatedDevice_Add(hs, masterRef) childDevice2.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Child childDevice2.AssociatedDevice_Add(hs, masterRef)
Originally posted by Rien du Pre View PostUpdate is now in the updater !!! (with device grouping)
Please delete all your Hub devices in HS first, then create the activity device(s) and lastly the Hub devices.
Code:feb-01 13:50:48 Updater Install/Update of package Harmony Hub failed. feb-01 13:50:48 Updater Error Installation of package Harmony Hub failed. Try disabling the plugin first, then re-try the update. feb-01 13:50:48 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Docs\HomeSeer HarmonyHub plug-in V3.3 documentation.pdf feb-01 13:50:48 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\hspi_HarmonyHub.exe feb-01 13:50:48 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Bin\HarmonyHub\msvcr110d.dll feb-01 13:50:48 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Bin\HarmonyHub\msvcp110d.dll feb-01 13:50:48 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Bin\HarmonyHub\HarmonyHubControl.exe feb-01 13:50:48 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\hspi_HarmonyHub.ini feb-01 13:50:48 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\html\Images\HarmonyHub\harmony-hub.jpg feb-01 13:50:48 Updater Installing package Harmony Hub feb-01 13:50:48 Updater Update HSPI_HARMONYHUB.exe downloaded successfully feb-01 13:50:45 Updater Downloading update: Harmony Hub feb-01 13:50:45 Updater Starting download of updates
Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
Try deleting the plugin, restart HS and install and configure the plugin again.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
... or at least disable it first.
(oh, and by the way: WOHO! )
EDIT: The plugin EXE got updated but it seems the documentation was not "updated" (if it is).HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostEDIT: The plugin EXE got updated but it seems the documentation was not "updated" (if it is).Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Okay, I only noticed is as U5tabil's log shows version 3.3 in the documentation filename. Mine only showed 3.2.
But as far as I can tell, the only part that actually got updated was the one that needed it: hspi_harmonyhub.exe.
I now have grouped devices!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Gallina View PostRein,
I would like to create events with channels in it,but the plugin only allows input of one digit. Is there a way to input more digits ie244 etc) or can you put it in.
Thanks good plugin.
Pat GRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by ozinnewy View PostThe Activities seem to update ok if I use the remote, however the Harmony Devices do not update. I have set the polling interval to 5 minutes in the plugin setup. Is it possible to update the devices?
What kind of update are you thinking about for devices ?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
