OK. I'm just going to keep my mouth shut from here on in.
Easy Trigger plug-in - Feature Requests
Originally posted by spud View Postguys,
if I implement it like this:
the user choose x and y, let's say x=2 and y=10 in this example
let's say t0 = 00:00
the plugin draws a random number r1 between 2 and 10, r1=3 for example
the event is triggered at t1=t0 + r1 = 00:03
the plugin draws another random number r2 between 2 and 10, r2=5 for example
the event is triggered at t2=t1 + r2 = 00:08
etc...
this way it's guaranteed that the event will be triggered at least once every 10 minutes, and no more than once in any 2 minutes period
no need for w and z parameters, am I missing something?
Any news on this front?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
I have a little bit to add to the random request for you to think about. How about a condition so the event won't fire some times? Like a % maybe.
AND IF 10% chance it won't fire
Something like that.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostI have a little bit to add to the random request for you to think about. How about a condition so the event won't fire some times? Like a % maybe.
Guest
I would buy this plugin if it made randomizing several lights really easy based only on a virtual device or similar set to home or away and another set dusk to dawn!
Guest
Hi Spud,
Would it randomize things in an easier fashion than in this thread?
http://board.homeseer.com/showthread...37#post1179137
http://board.homeseer.com/showthread...37#post1179137HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Guest
Originally posted by 519zwave View PostThanks Randy - looks like I'll be giving it a try!- Turn a light on at night at some random time from 0-5 hours, but not more often than once every two hours. The light has to have been off for at least an hour before it can come on again.
- Then it will turn off somewhere between 30-90 minutes after it is turned on.
- It will continue this process until sunrise.
So you can truly randomize both the on time as well as the duration of the light.
.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
This is outside the scope of this plug-in as they are actions.
I use a script to do this now but there have been a lot of requests. An action to increment or decrement a dimmer by X. This could also even apply to thermostat setpoints.
The action would be Then increase (decrease) Device Living Room lights by 10%
-or-
Then increase (decrease) Device Living Room Thermostat Heating setpoint by 1 degree
Another event action would be a toggle for binary devices - if the device is on, turn it off if it is off turn it on. Among other uses this could work with the random timer that S-F suggested to create random lighting events.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
-or-
Code:Set deviceX to $$DVR:<ref_X>: + 10
see this thread for more information:
http://board.homeseer.com/showthread.php?t=174716
Originally posted by spud View PostI think this one may already be possible using the "Set Device to Variable" action. I have recently added the possibility to add or substract a constant to the variable. So you can do something like this
http://board.homeseer.com/showthread.php?t=174716HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
