Originally posted by rjh
View Post
Cant find any devices
There may be a fix for this in the next build. We should be posting an update today, so try it again when its available.
Originally posted by will.i.am View PostI haven't gotten the thermostat to work yet. I have all the voice command boxes checked. When I change the Control Use dropdown for the Heat Set Point to 'Heat Setpoint' and hit Done, and then go back in to that Status Graphic screen, the Control Use box has reverted to 'Not Specified'. This happens for Heat and Cool Setpoints. I am on linux .243. Is this a bug, or am I forgetting to do something.
Originally posted by rjh View PostThere may be a fix for this in the next build. We should be posting an update today, so try it again when its available.
I really don't want to complicate things further with another option like this, it will just confuse most users.
I am confused as to why you want the names of your devices to be different from what you call them with voice and what you call them when they are displayed? Seems to me that would make it impossible to remember what to use for the VR. The names are for display purposes only, you can change them and that will not affect your events, or HSTouch. So renaming them for better voice control should be easy.
Originally posted by aldo View PostRich/Rick, fantastic job with this api. I do notice that you are also more active with this forum, that is great to see as well. As someone mentioned in previous posts, in the future would it be possible to add an extra field to change the name of the device for voice recognition. I have many light switches that unfortunately I called "Room" light switch, an example would be kitchen light switch, because I have two of them, if I do forget to say switch it will tell me that I have two of them and to narrow it down. I don't want to change the name of the device otherwise I would need to change them in hstouch, events and etc. I could create group but this seem to be a easy and clean solution. I heard people mentioning rooms to be added to the list and others having symbol in it. This way, the voice can be anything you like. Just my 2 cents. Great job.
Originally posted by aldo View PostRich/Rick, fantastic job with this api. I do notice that you are also more active with this forum, that is great to see as well. As someone mentioned in previous posts, in the future would it be possible to add an extra field to change the name of the device for voice recognition. I have many light switches that unfortunately I called "Room" light switch, an example would be kitchen light switch, because I have two of them, if I do forget to say switch it will tell me that I have two of them and to narrow it down. I don't want to change the name of the device otherwise I would need to change them in hstouch, events and etc. I could create group but this seem to be a easy and clean solution. I heard people mentioning rooms to be added to the list and others having symbol in it. This way, the voice can be anything you like. Just my 2 cents. Great job.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Echo can't find any devices
I tried everything in this thread; my Echo is still not able to find any of my devices. I am using HS3 ver 258.
I have also updated my Echo app, unlinked then relinked, created new devices but Echo finds nothing.
The HS3 touch App works properly on my iPad and Computer and I am able to control my devices via MyHomeseer.
IFTTT also works well on my Echo!
What else can I try!
Steve QLast edited by Steve Q; March 15, 2016, 09:33 AM.HomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Originally posted by Steve Q View PostI tried everything in this thread; my Echo is still not able to find any of my devices. I am using HS3 ver 258.
Steve Q
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
I tried this already. It did not work.
In the discovery process, does Alexa say "if the Phillips....is not discovered, press the button on the hub". It seems like echo is looking looking for non HomeSeer devices?
I think there is a communication issue between Amazon and MyHomeseer. The discovery period only lasts a few seconds, but I have about 300 devices.
Steve Q
Sent from my iPad using TapatalkHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Yeah, just ignore the Phillips message.
I think you're right. Are you sure myhs is pointing to your system and working?
Yes I'm sure it is pointing to my devices. When I login to myhs.homeseer.com, my HS3 pages come up. Also, HSTouch is working correctly. About a year ago, I had a problem that myhs was pointed to the wrong computer. I wonder if somehow an old backup of myhs got used to establish the link to the Amazon echo?
Yeah, I have never been a fan of myhs as it is slow and hit or miss. Its a necessary evil for this to work. You might try logging out of both, then logging back in.
I started over and went through the procedure again. The Echo still cant find any devices.
IFTTT still works and I am able to control my devices via myHS/HS3Touch, both on my computer and my iPad.
I also tried connecting to the Echo Skill for Homeseer. This does not work either.
Can anyone confirm that the myHomeseer to Echo setup is actually working?
Steve QHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Nope! Did not make any difference. No devices are discovered.
I think I can confirm that something in MyHomeseer is not working properly. I added a new virtual device to my setup. When I go to myhs.homeseer.com via my chrome browser, the device is there. However, when I use HSTOUCH, the device does not show up. An old out-of-date version is displayed. Something is definitely wrong!
Steve Q
Originally posted by rmasonjr View PostYeah, I have never been a fan of myhs as it is slow and hit or miss. Its a necessary evil for this to work. You might try logging out of both, then logging back in.
