There's really no point to my post. Just wanted to announce that I'm getting my Echo today.
My Echo arrives today
Yay!... more testersHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
My only issue with all this stuff is that it all works well until the API gets changed. Of course, it most likely occurs when your on business oversea...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
It was a breeze. Download the Echo app for the initial Echo setup. Once your Echo is connected to your WiFi, just request access to Homeseer here: http://homeseer.com/echo-access.html
Keep in mind this is for the Amazon Connected Home API which is still in beta. If you want a more stable experience use the Homeseer Skill which can be found in the Alexa app.
Originally posted by joey52685 View PostIt was a breeze. Download the Echo app for the initial Echo setup. Once your Echo is connected to your WiFi, just request access to Homeseer here: http://homeseer.com/echo-access.html
Barry
I installed 284 and my echo could not find my HS3 devices when I ran the discovery process. Then 284 broke my event engine so I rolled back to 218. Would be nice to upgrade HS3 to a stable version that supports echo and works. Curious what you're running. If running linux even better.
Originally posted by denisl View PostDid this work for you? What version of HS3 are you running?
I'm on Windows btw.
Originally posted by denisl View PostEnabling for voice control is making sure the "Control Use" setting under the Graphics tab of the device is anything BUT "Not Specified" correct?
Most of my devices have either "on" or "off" in the Control Use field so shouldn't they be discovered?
Greig.
Sent from my SM-G925F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
