OK, Here is the situation:
-Multiple USB sound cards
Multiple copies of Winamp, each setup to play on a specific sound card
I can start EACH Winamp, which plays MP3s fine to EACH card (read "Zone").
Without Winamp playing (just to tell everyone the details, consequential or not), I start One copy of the HS Speaker on the server (which has ALL the USB sound cards). Run
not a problem. So long as that is the Speaker.exe that is running. I can repeat this changing the Speaker.exe AND the command at the end (SCARD1,2,3, etc.).
Ok, start a second copy of Speaker. Now I have Myserver:SCARD1 and Myserver:SCARD2 running.
or
MyServer:*
or
nothing for that field (as in play on ALL instances for speaker).
Each speaker instance is configured to play to a different sound card. EACH one works fine by themselves (close ALL speaker apps. load one at a time run command to play on * or that specific instance).
So, why would this not work when I load multiples? (I have tried 2, and 3 copies of HS speaker app.).
Winamp can play out to each USB card without issue.
Is there a limitation to the Speaker application?
Is there a setting to get the HS speaker application to work on the same PC at the same time?
When the command is run, the wave shows up in each speaker application's message box indicating that it is playing. However, I did not notice any errors in any logs. I will try again to be certain (I did not take notes on paper and memory is telling me no errors as I would have copied it down).
Thanks to all!
--Dan
&hs.PlayWavFileEx "C:\Program Files\HomeSeer 2\Wave\chimes\westminster05.wav",0,-1,-1,False,"MyServer:SCARD2"
&hs.PlayWavFileEx "C:\Program Files\HomeSeer 2\Wave\chimes\westminster05.wav",0,-1,-1,False,"MyServer:SCARD2,MyServer:SCARD1"
MyServer:*
or
Thanks to all!
--Dan
