If you have both the Random Plugin and WeatherXML Plugin for HS3 installed you get some extra features in each plugin.
In the Random Plugin, on the Plugin page, you can select one of the Random Phrase Categories to allow you to use weatherXML information variables in the Phrase. Each time a phrase from this category is used, the text of the phrase will be sent to the WeatherXML plugin where the variables will be replaced with the actual data. For example the variable #temperature# will be replaced with the current temperature. All of the available variables will be displayed under the text area on the Random Phrase editor.
