Hi. This morning before heading to work I noticed a pool of water in my driveway. One of the large area sprinkler zones was running, but should have shut off about 3 hours before. I unplugged the 24 VAC transformer that feeds the rain8 relays and the water stopped, and I figured I would look at it some more when I got home.
When I did get home, I plugged the transformer in, and the sprinkler started up again. I looked at the zone status page and noticed that the status indicated "valve failure". I set the zone for a manual 2 min cycle, and sure enough, it turned off fine at the end of the cycle.
I do have the safeties set on the rain8 for 1 hr on this zone, so I am investigating why they failed to stop it, but I am guess the relay stuck somehow. But I have some ideas for some changes to MCS Sprinklers to make my normally ultra reliable system even more so.
1) If a "valve failure" state is detected, can HS email me an alert to notify me of the fault? I don't normally check zone status because the system is so reliable. But if MCS detects a fault, it would be great if it could tell me about it.
2) Can there be at least an option if a valve failure is detected to try cycle the zone for 1 or 2 minutes to clear the fault? And also to notify there was a failure and it was cleared? That would be automatically try what most people would do anyway.
Any possibility to see these added in a future release?
Thx
mike
Thx
mike
