New Dot2, connected, skill learned, but will not find any devices.
Do devices have to have all three states ON/OFF/DIM ?
Will a simple ON/OFF light not work or be discovered?
Will it not find or allow you to run events as the example in the Echo Dot announcement shows?
I've seen others talk about tricks with virtuals, but do we know if the api will be expanded to things like LOCK or run event if it isn't supported?
Is this an Amazon issue, MYHS issue, or heaven forbid a user issue?
I bought this for the sole purpose of using with HS3, and it can't find any devices or do anything, oh wait, it did tell me it was raining when I asked about the weather...DUH, I could hear it on the roof.
Thank you for any suggestions or answers in advance.
