Hi Mr. Weijenberg;
I'm hoping you can add this to the next update of the plugin.. It appears that when adding a X10 RF device your plugin leaves the the "Device Type" field blank,, Mark's Insteon plugin (and maybe others..) appears to scan for an X10 address and than if it is an X10 address check to see if it has a device defined in the "Device Type" Field if there is no device type text it decides it's an "Insteon X10" device".. It seems to me a subroutine that checks the that checks the letter house code that I have set up other than disable and X10 RFXCOM or something.. It wouldn't surprize me if you message back that your plugin already checks for this and it just isn't working here,, that's been the norm on this build !! Please let me know if you think you can do something ,, for now the work around appears to be to manually put as I do "X10-RF" and all is fine.. It's not a big deal it appears Mark's plugin doesn't do anything but add "Insteon X10" in the blank blank "Device Type" field...
TIA
Dave
TIA
Dave
