I'm not trying to be a pest, honest [emoji4]
Updated to 3.2.20.0 and had an issue with one of the accepted topics not saving the value to an HS device. Disabled the PI, deleted the PI database and recreated all devices. This resolved the issue with the device that was no updating it's value... but I now have another issue.
VS pairs for my light switch devices (the ones that send a simple On and Off via MQTT. They also subscribe to moteino/100/2/Office/Led1/control for controlling the light from HS) are not created.
I also receive the following error in the HS log as soon as accept is checked.
Attached are screenshots and the debug.
Update: Status updates do appear to function properly. For example, when the PI receives a MQTT message the HS device is updated. If I manually create the vs pairs Off=0 On=1, it appears the PI is publishing the topic as the light turns on and off properly. It looks like the issue is centered around the automatic generation of the vs pairs by the PI.
Also noticed that the new Misc settings in the PI have no affect on this device. Selecting a misc option in the PI does not set that value on the device. Does this need to be selected before clicking checking accept?
Apr-18 20:45:48 HSTouch Server WarningException on Value Change callback: Object reference not set to an instance of an object
