Due to not knowing where to post this I'll just put it here. Is it possible to send a hibernate on LAN similar but opposite to wake on LAN?
Sleep on LAN?
MeSteveTags: None
MeSteve
Could this be any use to you?
ie when target PC gets a message (email?) trigger this sleep function
http://board.homeseer.com/showthread...ighlight=sleep
JWD
Jim'll
I use a utility calll poweroff it can do all that you ask and can be controlled via homeseer.
Also ultramon can Wake-on-LAN.
MeSteve
Originally posted by Jim'llI use a utility calll poweroff it can do all that you ask and can be controlled via homeseer.
I use PsShutdown and WOL.
PsShutdown is from Sysinternals:
http://www.sysinternals.com/Utilities/PsShutdown.html
WOL is a utility from
They have 2 utilities, GUI and command line. As the Gui code did not work well for me (I posted about it in another area), I ended up using the command line (good ole trusty command line).
http://www.depicus.com/wake-on-lan/woli.aspx
I use this to turn on the media PC when one walks into the Entertainment Room (send IR to turn on surround, prep TV through serial interface, turn on media PC).
--DanTasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
does WOL power up a PC or just resume from hibernation?
the shutdown app that I use can't cope with apps that refuse to power off or present a pop-up.
The latest Adobe Reader (freeware) has a terrible bug in it - when used with FireFox, if you go to a non-responsive website, it hangs up forever. No way to kill it. Then when you later power-off, it hangs and causes a user-intervention in order to power off. I'm really mad at Adobe for this crap version.
Originally posted by pgaleHow good are these shut down apps in dealing with progs that don't normally like to be shut down i.e. Outlook?
Originally posted by Stevechdoes WOL power up a PC or just resume from hibernation?
PSShutdown can cope with it. You can force it to kill things after a certain amount of time. You can (I think) have it answer questions for you upon shutdown command. Although I'm not too certain of that last statement.
ah, I though WOL hardware and BIOS would not invoke what becomes a cold boot. I'm wrong, it says. Two PCs I've tried it on both left the power supply fan on when suspended or hibernated. Not what I wanted.
My current PC has ethernet on the motherboard and it does't support WOL. The BIOS does, but apparently you must plug in a PCI bus ethernet card with WOL.
Strange...when I hibernate my PC, it goes totally dead.
Then a WOL magic packet later, it's up, cold boots to where it pulls the hibernation data from the Hard drive.
MeSteve
Right, gotcha. I use hibernate...never had good experiences with Sleep modes and desktops.
