Does the GoControl WI15VZ-1 Z-Wave Irrigation Controller have 'internal' timers that you can set to turn off zones in an emergency in case the z-wave signal (for 'off') does not get to the controller? I know the Relay8 has this feature for this purpose.
GoControl Z-Wave Signal OFF Emergency Timer
**** Do You "Cocoon"? ****Tags: None
I have one and it does have internal programmable timers. However I have not been able to get any directions on how to set it up.
the parameter list from GoControl is rather lacking. The only parameter they sent me was to change the rain sensor from a normally closed status to a normally open status depending on the rain sensor you have.
I've been using an event for three zones, 10 minutes on "A", then wait 5 seconds, then 10 minutes "B", etc. I cycle through the three zones twice.
I suppose you could write a separate event to automatically shutoff the controller after "X" minutes regardless of operation status.
Originally posted by BraveSirRobbin View PostDoes the GoControl WI15VZ-1 Z-Wave Irrigation Controller have 'internal' timers that you can set to turn off zones in an emergency in case the z-wave signal (for 'off') does not get to the controller? I know the Relay8 has this feature for this purpose.
As far as timing of the valves in an event I use a setting from the drop-down and select a value that is greater than the time you are going to water that zone with and then add in a wait statement that is the exact time you want that valve to run and then turn off the valve, wait a few seconds and repeat for next valve. See pic
Thanks for the reply.
What I was after was the existing of the internal timers that racerfern mentioned.
This is important in a sprinkler controller as it is the 'emergency' stop in case the zwave network command for off/stop does not get through--------------------------------------------------
