Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old March 28th, 2017, 09:09 AM
MEB MEB is offline
Viewer
Control Occupancy Virtual Device with Alexa?
I followed the How To and made my virtual device for home, away, and night. But I cant figure out how to trigger them with Alexa, she seems to be only able to do on and off commands. On my vera I was able to do this with new events and just trigger them.
Old April 21st, 2017, 09:06 AM
MEB MEB is offline
Viewer
So 500+ views and nobody can help? Even a "this can't be done" would be helping.
Old April 21st, 2017, 09:24 AM
waynehead99 waynehead99 is offline
Super Seer
This can be done, but not directly with the current setup you have (not telling homeseer). You would need to create virtual devices to control this one and then you can voice control those, "Alexa, turn off blah blah". Otherwise you would need to use the skill instead (Alexa, Tell Homeseer to). This gives you a bit more control, especially if you are using Jon's alexa script.
A little more detail on what the device does and what you are wanting to do exactly, will get you more answer. Right now it's a little vague other then you want to control a virtual device by name.
Old April 21st, 2017, 04:42 PM
Andy Andy is offline
Seer Deluxe
IFFT is perfect for this!
I use IFTTT and say "Alexa, Trigger Bedtime". IFFT triggers Bedtime event. I have set up virtual devices that are updated when say Bedtime event is triggered via IFFT.
HTML code is On
Virtual device not discovered by Alexa Rvtravlr HomeSeer Amazon Echo Skill 1 December 30th, 2016 12:48 PM
Challenging Event - Alexa and Virtual Device denisl HS3 Event Clinic 9 July 18th, 2016 08:34 PM
Can a virtual Harmony Hub device control a real device or activity in HS? rayvino Harmony Hub 15 April 13th, 2016 07:53 AM
How To Create a Virtual Device to Designate Occupancy macromark How-To's 6 July 2nd, 2015 03:55 PM
Key fob to control virtual device AquaCom HS3 / HS3PRO Discussion 2 February 13th, 2014 04:54 PM
