Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
  #21
Old October 16th, 2017, 05:04 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Originally Posted by TechFan View Post
Hm. Okay. I didn't realize the functionality had been implemented that recently. I guess my timing is working out. So, does the HS3 version need to be at a certain version as well?
the release version (130) was published on June 16th.... there have been 18 subsequent beta releases since then. If you have the most recent NON-BETA version of HS3, that should be fine.
  #22
Old October 16th, 2017, 06:18 PM
TechFan's Avatar
TechFan TechFan is offline
Time flies sometimes. . .I have had a lot of transitions here, so haven't been keeping up.
Still having to use a ZWave version that is newer than June 2017 is pretty recent in comparison to having these bulbs since 2014 (I have had a few since then, but got a batch in April 2017, then again more in August).
Thanks again for confirming. Looking forward to controlling the dimming speed!
  #23
Old October 17th, 2017, 12:23 AM
TechFan's Avatar
I did just download the file. . .and HS complains it can't handle the .hec file (filename.hec has invalid extension, only .hex are allowed). I need to read change logs and do the extensive backups before applying the latest HS3 update. I have the latest released ZWave already .130. Is the change log for the newer ZWave posted to the beta plugin page (doesn't always get there).
Thanks. Will have to wait and do some prep before I can upload the firmware it appears.
Slow going, but getting all my bulbs updated. . .and they do dim very quickly now! :-)
I realized, that I have one non-LB601Z-1 bulb. . .the HomeSeer branded Domitech bulb. . .
HomeSeer HS-DTA19+ Z-Wave Plus Smart Bulb
Is there a firmware update for that that might support the same configuration options?
  #24
Old October 17th, 2017, 09:20 AM
macromark's Avatar
Our OEM manufacturer was the same one that also made the Nortek bulbs. I assume the Nortek firmware should work on those too but I've not tested it.
  #25
Old October 17th, 2017, 10:03 AM
racerfern racerfern is offline
Close to a dumb question but, if I were to put this in a closet with a pull cord or a table lamp with a switch, could I still just pull the cord or push the switch to make the light come on?
Or does the bulb only get activated from a z-wave controlled device, whether another zwave device or an app?
  #26
Old October 17th, 2017, 10:19 AM
MNB's Avatar
MNB MNB is offline
Not a dumb question.. The problem with a pull cord/ table switch is that if you turn it off there is no electricity to the bulb so when you try to use your z-wave controllers it is unable to communicate with the device until you turn the power back on via cord/switch. Mike
Computer: CUK Intel NUC7i7BNH
Op System: Windows 10 Pro - Work Station
HS Version: HS3 Pro Edition 3.0.0.435
Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
  #27
Old October 17th, 2017, 10:31 AM
macromark's Avatar
The problem is a tiny bit worse than that. If the bulb is being used as a repeating node (likely), then cutting the power from it can also cause slowdowns in the network as commands and (especially) responses may be routed through that node.
I have a few of these bulbs in pull-chain fixtures at home. I've actually removed the chains to prevent this problem from happening... and I've mounted wall controllers instead.
  #28
Old October 17th, 2017, 10:59 AM
TechFan's Avatar
I'll try again. I tried it once. It uploaded the firmware but didn't ever install.
  #29
Old October 17th, 2017, 11:44 AM
TechFan's Avatar
I aborted the process that didn't finish, cancelled it, then started again. This time it worked, so now all my bulbs are set to dim much faster, in steps of 10 (parameter 9) to complete in 1 second (parameter 10).
  #30
Old October 17th, 2017, 04:51 PM
@Macromark and @MNB - so, one of these bulbs is on and I shut if off via z-wave control from HS3. Then... someone physically turns off the switch (for whatever reason), now I can't turn the light on from HS3 because the switch is off, got it. However, if the light is off from HS3 and the switch is off physically, will turning on the switch (non z-wave) make the light come on, or does it still have to be turned on via HS3 somehow?
I hope I didn't overly wordy there.
I was about to buy a bunch of these, but now I'm not so sure.
  #31
Old October 17th, 2017, 04:54 PM
MNB's Avatar
MNB MNB is offline
My experience is that if you apply power via the switch will turn the light on, it doesn't require zwave to turn it on. Mike
  #32
Old October 17th, 2017, 05:10 PM
TechFan's Avatar
The behavior (when turned on by the physical switch) can be configured. By default, the lights come on at 100% when they get power again. You can configure them to return to Last On level (no matter if it was off). . .or to last state (off if it was off, on if it was on).
The concern @Macromark was mentioning is that your ZWave network may get confused if nodes it is depending on (the bulbs) are turned physically off at the switch.
  #33
Old June 7th, 2018, 01:31 PM
neiltimms's Avatar
neiltimms neiltimms is offline
When flashing the bulbs to 5.12, how long should this normally take? I haven't received any errors but my 1st one has been "Firware Update Status: Receiving" for about 10 minutes now!
Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
  #34
Old June 7th, 2018, 01:38 PM
macromark's Avatar
Along with that message, you should also see a byte counter counting the number of bytes that have transferred to the device. If that byte counter is not moving, things may be stuck.
  #35
Old June 7th, 2018, 01:51 PM
neiltimms's Avatar
Hi Mark, I am not seeing any numbers at all. I have aborted a couple of times, re-selected the file etc. but it just seems to sit there. I have also restarted HS and restarted the interface. No change.
  #36
Old June 7th, 2018, 01:53 PM
neiltimms's Avatar
This is what i always get. I am using the latest release of HS and the Z-Wave
  #37
Old June 7th, 2018, 01:59 PM
macromark's Avatar
Please post your support profile.
  #38
Old June 7th, 2018, 02:25 PM
neiltimms's Avatar
Current Date/Time: 6/7/2018 1:24:35 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.425
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 0 Days 1 Hour 21 Minutes 5 Seconds
IP Address: 192.168.2.4
Number of Devices: 103
Number of Events: 48
Available Threads: 400
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed: Windows Defender
  #39
Old June 7th, 2018, 02:35 PM
macromark's Avatar
Please include your plug-ins with this...
  #40
Old June 7th, 2018, 02:56 PM
neiltimms's Avatar
Sorry, all the details here
My two cents: Linear/Evolve vs GE Z-Wave switches mikedr HomeSeer Z-Wave Plug-in 19 January 14th, 2015 09:22 PM
WIFI light bulb Steve Q HS2 / HSPRO 2 October 6th, 2012 05:11 PM
insteon LED light bulb! pbibm Insteon Plug-in (Mark Sandler) 27 August 30th, 2012 10:55 PM
New Insteon Light Bulb Jingoro Lighting & Primary Technology Discussion 1 June 19th, 2012 12:39 PM
Samsung LED light bulb teardown includes objective dimming numbers FeMan Lighting & Primary Technology Discussion 0 February 10th, 2012 03:13 PM
