Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old July 13th, 2017, 04:31 PM
Ivan8ias's Avatar
Ivan8ias Ivan8ias is offline
Web interface
Hello,
All of a sudden I can't access my HS3 program using the web interface. Nothing changed on my network or computer. I am running Windows XP Pro. Is there any way I can change that IP?
I have no access on other network computers and browsers to anything to do with HomeSeer HS3. Please help!
Thank you.
Old July 13th, 2017, 05:47 PM
S-F's Avatar
S-F S-F is offline
Have you verified that HS is actually still running? On the system that HS is running on, did you perhaps setup another web server? I suggest you try to log directly into your system HS is running on and verify that it's indeed still running. If so, shut it down and in the settings.ini file change the port from 80 to something else, like 81. Then when you try to log on to the web interface just append the URL with :81. So something like 192.168.1.123:81
Oh. And also rule out any firewall possibilities by turning it off (on the HS machine) momentarily and trying to access the web UI while it's down.
Originally Posted by rprade View Post
Old July 13th, 2017, 08:04 PM
Ivan8ias's Avatar
Thank you for your suggestions. Unfortunately, it did not help. I copied the HomeSeer folder to back it up before I went into Windows Install and selected the program and chose repair. Same results. Do you think that it could be something to do with my network? I have been having problems connecting to my other computers. I have no problem accessing the internet. I have a Verizon FiOS Gigabit router that has all of the computers connected to the router directly. I have contacted Verizon support at the highest level and they couldn't find any problems. They told me to go into the router settings and change the IP on the computer running HS3 to static. That didn't help. I didn't think it would. I can't imagine why all of a sudden did this. I would appreciate any other suggestions. Thank you again.
Old July 13th, 2017, 10:50 PM
Rupp's Avatar
Rupp Rupp is offline
If you login to your HS3 sever and start HS3 up are any errors being reported or shown?
-Rupp
Old July 14th, 2017, 12:58 PM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
Can you ping you Homeseer system from another pc on your network?
Sent from my SM-G925F using Tapatalk
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Old July 14th, 2017, 01:11 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Also try find.homeseer.com from a PC on the same network.
HTML code is On
Frequent "Z-wave interface Z-Wave interface did not fully initialize..." messages Kirkla79 SmartStick+ 2 May 29th, 2017 06:16 PM
Homeseer Z-Net Interface Model not listed when adding new Interface confortif Z-NET 2 June 22nd, 2016 04:42 PM
Zwave interface can't find USB stick; uninstalled zwave interface blackhole dixon HomeSeer Z-Wave Plug-in 5 November 20th, 2011 09:47 AM
building a new interface[iphone hst interface gfx] Robin_f Clients - Apple iPhone/iPod/iPad 28 April 22nd, 2010 07:30 AM
What's the best interface goddard99 HS2 / HSPRO 4 December 17th, 2006 07:51 PM
