Do I need all this?
    Do I need all this?
    I still have NET 1,2,3 installed and off course NET4. do I require them all or can I delete 1 2 &3?
    Current set up:
    Current Date/Time: 15/11/2017 19:23:41
    HomeSeer Version: HS3 Pro Edition 3.0.0.362
    Operating System: Microsoft Windows XP Professional - Work Station
    System Uptime: 6 Days 21 Hours 3 Minutes 30 Seconds
    Number of Devices: 606
    Number of Events: 242
    Available Threads: 400
    License: Registered
    Enabled Plug-Ins
    2.0.47.0: BLBackup
    2.0.8.0: BLCpuAdvisor
    2.0.5.0: BLGarbage
    2.0.6.0: BLPlugins
    2.0.127.0: BLRadar
    2.0.93.0: BLRF
    1.0.3.0: BLShutdown
    3.0.0.40: EasyTrigger
    3.0.0.24: ImperiHome
    3.0.1.109: PHLocation
    3.3.5.17921: SMS-Gateway
    3.0.6377.20892: UltraWeatherWU3
    3.0.0.42: X10
    3.0.1.152: Z-Wave
    sigpic
    A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
    I would leave the dot net stuff alone.
    Do you still have that 2 drive 2.5" SATA cage in the front of your Foxcomm D525?
    If you do you can purchase SSD drives for trying new OS's with HomeSeer 3.
    A 64-120Gb drive would work just fine for Ubuntu Linux 16.04 64bit or Windows 7 embedded or Windows 7 lite.
    You could dual boot using current XP Pro build and a second OS build.
    Auto mator
      Thanks Pete, good advice as usual. I would like to try linux, but the cpu is way below min spec for linux. Can you remember what socket is on the motherboard?
      sigpic
        Yes the Intel Atom D525 is soldered on to the motherboard.
        It would run Ubuntu 16.04 64bit fine.
        You can test a live DVD or USB stick without installing it on a hard drive to check out the speed.
        You can also test Linux on an RPi3 or Pine64 2Gb computer or new Rock64 4 Gb computer running it on eMMC.
        Auto mator
          Thanks Pete, I'll let you know how it goes.
          sigpic
            A D525 runs Linux just fine. Had one running my firewall for several years before moving to an even lower power one. Depending on how many plugins you have I suspect it would be great with HS3. Linux requires fewer hardware than windows, so if HS3 is running on your D525 under Windows it will run as good or better under Linux. Plugin compatibility of course is a different matter.
            HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
            Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
            Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
            Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
              New SSD drive arrived and Ubuntu Linux installed, working great. Downloaded HS3 for Linux and extracted the TAR, but how do I install it, tried to understand HST's installation guide without success.
              Can you help?
              sigpic
                @Gordon,
                Sounds good.
                Guessing you have latest 16.04 / 64 bit Ubuntu running with latest Mono 5.X running.
                Here utilize Webmin which is an HTML GUI to manage a box without a desktop.
                There is really no installation for Homeseer 3 running in Linux. It is just a directory and all you do is manually run the Homeseer 3 program inside of the directory.
                Running Homeseer 3 is easy.
                1 - you can run it manually opening up a terminal windows remotely or on the box itself, and doing a sudo ./go in the Homeseer directory. Leave the terminal window open while you test and check out Homeseer 3 or
                2 - run a cron Homeseer 3 start on boot
                3 - create a Homeseer 3 systemd service to auto magically start Homeseer 3.
                Suggested first steps would be installing Webmin ==>
                Installing on Debian
                At an SSH prompt type the following:
                1 - wget http://prdownloads.sourceforge.net/w..._1.860_all.deb
                2 - sudo apt-get install perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl apt-show-versions python
                3 - wget http://prdownloads.sourceforge.net/w..._1.860_all.deb
                4 - log in to your Webmin GUI and create a CRON job on boot.
                5 - Got to Webmin==> System ==> scheduled CRON jobs.
                6 - create a new Cron Job and call it Homeseer start.
                Use this:
                sleep 60 && exec sh /usr/local/HomeSeer/autostart_hs
                Reboot.
                You can disable this once you are comfortable with writing a systemd homeseer.service auto start entry.
                Once in Homeseer 3 GUI you can register your Homeseer and start to tinker with it toot suite.
                Are you familiar with using SSH?
                Are you using the Ubuntu Desktop?
                If using the auto login for the desktop you can run the Homeseer 3 script on boot up of the Ubuntu Desktop.
                Baby steps as Linux is a bit different from Windows.
                I find using the command prompt much easier / faster than the Desktop and currently running two Homeseer 3 boxes headless with only HS3 Webgui access and SSH access and or Webmin Access.
                If you have a Windows desktop around you can install Putty to run SSH from it and WinSCP to manupulate and edit files on your Homeseer box.
                Auto mator
                  @Gordon,
                  Sounds good.
                  Use this:
                  Reboot.
                  Thanks for quick reply Pete, not sure if mono is installed unless it is in the install package for Ubuntu Desktop.
                  I read that HS3 folder has to be in the rot directory, am I meant to copy it to there?
                  sigpic
                    One great suggestion you made Pete was to use a new SSD, it was getting dark by the time I had Linux installed an failed to install HS3, so just shutdown, changed the drives and fired up the pc with XP and hs3.
                    Worked perfectly.
                    thanks.
                    sigpic
                      I do not think that Mono is installed with the installation of Ubuntu 16.04 64 bit. Note it is suggested to run Linux in 64 bit. Personally think that Homeseer 3 (32bit) runs faster in Ubuntu 64 bit.
                      [ATTACH]64532[/ATTACH]
                      Note too you want to create a lite version of Ubuntu. (server or lite desktop called LUbuntu). LUbuntu is what Homeseer uses with their S boxes.
                      If you need to start over again then I would suggest you do that with LUbuntu. Takes 15 minutes to install the OS. Note that I went heavier here with Ubuntu LTS.
                      The lite arm box is using a 32Gb microsd card for Ubuntu 16.04 64bit. The larger box is using a 120Gb .m2 Sata drive. (geez it is the size of my thumb).
                      To install mono follow the steps here for whatever OS you are using. Do this stuff via SSH.
                      For Mono install on Ubuntu 16.04 it is easy.
                      1 - sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
                      2 - echo "deb hxxp://download.mono-project.com/repo/ubuntu xenial main" | sudo tee /etc/apt/sources.list.d/mono-official.list
                      3 - sudo apt-get update
                      change above xx to tt.
                      1 - sudo apt-get install mono-complete
                      2 - sudo apt-get install mono-vbnc *
                      3 - sudo apt-get install aha *
                      * specifically needed for Homeseer 3
                      BTW Microsoft now owns Mono.
                      Checking my HS3 Pro box I see:
                      ICS-HS3Pro:~# mono -V
                      Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 20:37:08 UTC 2017)
                      Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
                      I read that HS3 folder has to be in the root directory, am I meant to copy it to there?
                      You can install the HS3 folder any place. The Zee2 default directory is:
                      /usr/local/HomeSeer
                      Other users install it in the home directory, /opt directory or wherever.
                      I have mine installed in the root directory just cuz it is easier to type to get to.
                      IE: /HomeSeer.
                      Just make sure all of the Homeseer users can get to it.
                      I do this chmod -R 777 <homeseer folder>.
                      Another thing you want to configure is remote root access. By default Ubuntu does not provide a root password.
                      I just do a passwd root to create a password and tweak the ssh configuration a bit.
                      Here create new users and use same users for Homeseer:
                      new users created are pete and homeseer. I disable the default user.
                      Creating a new user and putting in to sudo is easy.
                      1 - sudo adduser username
                      2 - usermod -aG sudo username
                      So Gordon I am guessing you still have the two drive 2.5 hotswap cage in the front and DVD RW writer drive in the front of your FoxCon D525 PC. Here not using DVD / CD ROM drives much anymore and have gone to writing a boot install OS on a USB stick.
                      I still have the identical Foxconn computer here; still running 24/7 even though I do not use it.
                      Wondering now how many years ago that a bunch of us here purchased the same computer for Homeseer use.
                      Mods here same as yours ==> picoPSU, dual drive cage (well and removal of PSU).
                      It was around the same time of the year - November-December.
                      Thinking that maybe there are a few Homeseer users using the Foxconn D525 today for Homeseer 3.
                      Baby steps Gordon....savor the installation and see that it's late there now....go to bed.
                      Auto mator
                        [I]So Gordon I am guessing you still have the two drive 2.5 hotswap cage in the front and DVD RW writer drive in the front of your FoxCon D525 PC. Here not using DVD / CD ROM drives much anymore and have gone to writing a boot install OS on a USB stick.
                        Yes still there, best thing ever. DVD no longer works, using a usb dvd drive
                        That would be interesting to know.
                        sigpic
                          Pete, have installed mono, but when I try and run HS3 get this error
                          Unhandled Exception:
                          System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
                          File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
                          also how did you manage to get HS into the root directory, I don't have permission
                          sigpic
                            Gogs,
                            You do know that none of your .txt scripts will work under Linux? They will all need to be converted to VB.NET
                            Jon
                              Originally posted by jon00 View Post
                              Gogs,
                              Hi Jon00, yes I knew one would not thought it was the other way round though.
                              A job I am not looking forward to
                              sigpic
