I read through a few threads here and it sounds like this plug-in can't connect to the Caseta non-Pro anymore because Lutron changed the key. I have a Caseta non-Pro and I can't get the plug-in to connect to it. It reports "Telnet and SSH Not Connect" for my Caseta hub, which it thinks is called "ScenesS1." Should this work? Happy New Year!
Does this plug-in work for non-Pro hubs?
The pro work with telnet, asp yes this is the safer way to go, telnet don't have the ability to import the device so you need to add one by one,
Pro also work with SSL but I'm struggling to have this work in VB. I'm still working on it.
If you change from non pro to pro just make sure you register your device in the same order as the non-pro so you won't have to recreate them
