Hi All
Wondering if anyone could help with an issue I'm having with the LIFX mini color bulbs which I've tried to illustrate in the below screenshots.
The first attachment is the lamp selection I can see when I set the UltraLight 3 White option inside an event, which works fine. Lamps selected and then triggers.
The second attachment is when I select the UltraLight 3 Color option. When I drop down to select the lights I cannot see any there to select.
This is the same when I select Waveform also.
The bulbs are color and work using the LIFX app on my iphone.
LIFX version is 3.0.6516.32486
Any help would be great!
Cheers
Andy
Cheers
Andy
